Cyrus PSX diy - Advice needed - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd March 2012, 12:45 PM   #1
Question Cyrus PSX diy - Advice needed
I just bought a diy PSX, and I would like to know an opinion from you. Is it well constructed? Is it "safe" to connect it to a Cyrus Two?
Here ar some pix of the diy PSX internal:
http://img141.imageshack.us/img141/8504/dsc05788md.jpg
http://img11.imageshack.us/img11/5329/dsc05787h.jpg
http://img827.imageshack.us/img827/8...6194048641.jpg
http://img717.imageshack.us/img717/9533/dsc05784r.jpg
..and here is the Cyrus Two power supply schematic:
cyrus_2_power_supply.pdf
thanks in advance
Old 4th March 2012, 11:17 PM   #2
GloBug is offline GloBug  Canada
Banned
It looks to be well constructed.
How old is it? You may need to replace the 'lytic caps.
I did not download the PDF from that site.
If you post the schematics and what you need/have for voltage requirements somebody might be able to help more.
Old 5th March 2012, 12:05 AM   #3
sippy is offline sippy  United Kingdom
hey there,
I have a Cyrus 2 + PSX in daily use......
The PSX should, as far as i know, produce +/- 40v.
BE AWARE that if this 'diy psx' does produce the above, you cant just plug it into the amp - there are two fuses that need to be removed from inside the amp. These de-couple the on-board ps leaving it dedicated to power the 'pre-amp' section (the C2 still needs to be hooked up to the mains) and the PSX powers the 'power-amp' section.
I refer you to this thread: cyrus 2 ,plenty of info for the Cyrus 1/2
Expect the '2 to sound slightly 'darker' with the PSX, I'd also advise to leave the '2 powered up permanently (switch off the PSX though), it dont do it any harm and its always part ways to being warmed up....... enjoy :-)
Old 5th March 2012, 05:12 PM   #4
Thanks for the answers....
@GloBug
I do not know how old is this PSX, but I think that it is not older than 10 years, so I guess the caps are still ok...here is a pix of the Cyrus Two power supply. Couldn't find a Psx schematics, but I read on the net that it is pretty similar to the Two power supply section...
http://img692.imageshack.us/img692/8...wersupplyb.jpg
...and here some pix of the original Psx...
Recent image by chalshus on Photobucket
http://img26.imageshack.us/img26/5415/psxcloseup.jpg
@sippy
Unfortunately, the psx is still in the UK, and now is "parked" in London at a friend's house. Actually he is not a teckie...just a record collector, so I cannot measure the voltage at the moment. As soon as I will have the unit I will do it, but I do not know when I will be able to get the PSX.
I know the Cyrus Two/one thread by heart, because I'm using now a Cyrus One, which was recapped by me, following the advices found on that thread...
What I am most concerned of is the trafo of this diy PSX. I searched the net to find some info about the brand, but with no luck. I do not know either which is the trafo voltage...no sign on it. Do you know by chance what type of trafo is it...here you can find all the info that I have...
Made in UK...can you help me?
Regards.
Old 6th March 2012, 10:19 AM   #5
If the PSX is newish then it must be similar to the current version.
The original PSX is quite different from the two versions of the PSXr.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th March 2012, 10:22 AM   #6
The brand is ILP.
I think they were taken over by an Irish transformer company.
ILP were the cheap end of the transformer market.
The advantage is that copper was used more freely, so good regulation is available.
A "proper" audio grade transformer will bring with it some advantages. But expect to pay upto double the price of the lower end of the current market.
Toroidy supplies cheap high quality audio grade transformers.
I have two for a balanced F5. They measure well.
regards Andrew T.
Old 6th March 2012, 11:06 AM   #7
The PSX is not an original one, is a DIY project.
Old 6th March 2012, 11:08 AM   #8
The brand is ILP.
Hi again Andrew,
thanks a lot for the info! They still have a website, but no sign of the transformer inside my PSX. I will send them an email, hope they have some info.
Thanks again.
Old 6th March 2012, 11:23 AM   #9
I think the ILP transformer codes are on the internet.
Each VA & Voltage is defined by the ILP code number.
regards Andrew T.
Old 6th March 2012, 11:31 AM   #10
Unfortunately there is no matching codes between the psx trafo
and the pdf of the the ilp...
http://www.ilpelectronics.com/images...mers_mains.pdf
The type of my trafo is: 7E137
Maybe it is not a "standard range"...
Btw, I already sent them an email.
Cyrus PSX dead gfredriks Solid State 98 4th June 2014 05:12 PM
Advice on refurbishing a Mission Cyrus 2 & PSX ianp Solid State 6 13th February 2014 11:47 AM
Cyrus 2 Repair Advice Needed roguerobot Solid State 65 16th May 2013 07:27 PM
mission cyrus 2 PSX bonjaribros Solid State 4 31st July 2008 10:28 PM
Copyright 1999-2017 diyAudio
