How do I calculate power supply current after rectification?
Old 2nd March 2012, 12:00 AM   #1
fingersoccer is offline fingersoccer  United States
Question How do I calculate power supply current after rectification?
So I have a power supply I'm using to power a chip amp. The transformer is rated at 250VA with 24V secondaries. I calculated the rails voltage after rectification with this equation: Er = √PR(1.4) + 4 (or, more simply, 24V * 1.4), which comes out to around 33.6V.
I would like to knock the voltage down to 15V to use with a preamp, probably with a switching regulator since I understand they're more efficient than a linear regulator. I need to understand a few things before I can do this:
  1. How do I calculate the power supply's current after rectification?
  2. How do I calculate the current going to the preamp after regulation?
  3. How do I figure out the current requirements for the preamp?
Here's an image if that helps:
Thanks, thanks, thanks!
Old 2nd March 2012, 12:43 AM   #2
pdul is offline pdul  Denmark
You forgot -1,2v drop in your rectifier bridge
Old 2nd March 2012, 12:48 AM   #3
The most simple would be to use LM317/337 as regulators for your preamp. you can draw up to 1,5 amp from those, more than enough for most preamps.
Old 2nd March 2012, 12:55 AM   #4
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
PSUDII will help with the basics.
The current requirements of your regulator are specific to its circuit, as are the current requirements of your pre-amp - gotta know those first...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 2nd March 2012, 01:58 AM   #5
sawreyrw is offline sawreyrw  United States
You need to work backwards. Determine the output power of the amp and preamp. Then determine the power required at their inputs. This is not a simple task. Now keep going until you finally determine the total input power.
How do I calculate power supply current after rectification?Hide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 09:03 AM
Power tube maximum current draw from a power supply razorrick1293 Tubes / Valves 4 4th November 2011 11:48 PM
how to calculate current requirement chicago_mike Tubes / Valves 9 3rd January 2009 05:13 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
Can you make a +/- supply with valve rectification ? Shoog Tubes / Valves 3 31st October 2004 06:35 PM
