Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th February 2012, 07:46 PM   #1
Default Dual Power supply for my pre-amp
This Thread is No longer Valid, Thank you for your Attention.
Old 29th February 2012, 07:56 PM   #2
picowallspeaker's Avatar
Hi.
Usually the old and popular 78XX (positive side ) and 79XX (negative ) are used for this purpose . By using one 7815 and one 7915 ( beware of the legs that are different position for ground and output...also input ! ) you'll have a regulated dual supply. If you want , you can use variable voltage regulators , to get the maximum voltage allowed by your circuit ; those are the famous and old LM 317 and LM337 (negative side ) .Old but good !
Old 29th February 2012, 08:01 PM   #3
Originally Posted by picowallspeaker View Post
Hi.
Hello,
Thanks for the quote,
Well.... Without the regulators i am getting a output of ±42VDc from this board where as the input to the board is 18-0-18ac, IS THAT NORMAL??
Old 29th February 2012, 08:05 PM   #4
What's the capacitors voltage ?
Old 29th February 2012, 08:06 PM   #5
pdul is offline pdul  Denmark
with the schematic shown it is not only abnormal it is impossiple
Old 29th February 2012, 08:10 PM   #6
Otherwise you have an invention that can save the worlds energy situation
Old 29th February 2012, 08:18 PM   #7
Did someone remove some posts? why?
Old 29th February 2012, 08:22 PM   #8
Half of this thread disappeared suddenly How? Why?
Old 29th February 2012, 08:24 PM   #9
Voltage doubles ,thread halves
Old 29th February 2012, 08:37 PM   #10
seems like this thread is running in both solid state and powesupply
Dual Power supply for my pre-amp SLAK Solid State 26 29th February 2012 09:50 PM
Phono-pre-amp+power supply pcb Roushon Analogue Source 41 15th August 2011 12:23 AM
Supply for dual mono pre-amp Tex Houston Power Supplies 3 17th May 2007 09:26 PM
Using power supply to power pre-amp? preiter Chip Amps 4 11th May 2006 12:52 PM
Copyright ©1999-2013 diyAudio
