This is being sold as a replacement for the "WallWart" by a famous manufacturer:
#2 |
The regs just wont work as the input will fall below Vin(min) causing regulator dropout on every half cycle.
At very least the 1000uFs should be on the other (input) side of the regs. |
#3 |
No, I would not. In addition to the previous post, the common mode rejection transformer should be on the input side of the regulators followed by a capacitor, and the inductors to pos common and neg common are just (wrong) asking for oscillations, just tie them to ground.
#4 |
The common mode choke should be on the other side of the regulator as well. (I see you said before I could add a picture of output impedance). This takes a 7812/7912 and turns it into a worse device.
#5 |
:envy:
Lots of postings with readings of an AP... Is this becoming a standard equipment for DIY? ...must start saving money.... :envy: Erhm, back to topic: 1. Pretty strange, it also does not appear to be escpecially cheap. 2. Are you sure that the cap on the 79 output is 1uf? |
#6 | |
The Z-Out of an LM78xx regulator would be about 8 milli-Ohms @1kHz. I bought the AP pretty in-expensively, but had it upgraded by selling my 1987 MB. :wink: I like the line of Inspector Clousseau ("Pink Panther") when he was asked how his wife afforded such expensive clothes on a police inspector's salary: "She saves a little bit out of the household budget." |
#7 |
I have to review our household budget.
...confident that this will cover my financial gap for AP-purchase.... |
#8 |
More problems -- the 7912 died! -- can't take the stress of all that unfiltered ripple. The choke values are specified as 22uH and 2x22uH, but the common mode choke measures 36uH.
Here's a simulation of what the output is supposed to look like on a 7812 without (green) and with the chokes: |
#9 |
The original Wall-Wart was most probably safety tested and labeled. Often equipment manufactures use Wall-Warts so that they don't have to safety test their units.
Has this commercial replacement been safety tested?
Kevin |
#10 |
There's not even a manufacturer listed on the device. It says, however: "Designed in the United States and Made in the PRC".
Does not give me a lot of confidence in the state of engineering education in the US. ...and as I am in the "coatings business" in the US, I can smell the organic solvent based coating which would probably be illegal in the US. |
| How do I know a 7812 is broken? | ericpeters | Parts | 16 | 7th March 2013 02:55 AM |
| 7812 vs 7912 | KU40 | Solid State | 4 | 13th June 2006 03:30 PM |
| 7912 needing minimal load? | Pierre | Power Supplies | 3 | 25th May 2006 12:28 PM |
| Lm7812/7912 | kinser | Chip Amps | 9 | 22nd November 2004 09:55 AM |
| 7812/7912 regulator questions | Solid Snake | Solid State | 48 | 1st December 2003 05:42 PM |
