Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th February 2012, 12:53 PM   #1
Default Way to reduce rail voltage ? (wise type ?)
I'm currently planning an amplifier, and it seems that I couldn't find a good transistor that have high enough Vce and other specs I wished, so I only have my BC550C/560C to use, which is lower Vce. As my rail voltage from my transformer after filtered and rectified, it is roughly 27V-28V, I need to lower it to something from 20V-22V to cope for BCs.
I'm current finding some method of reduce rail voltage (regulator ?) with minimum dissipation, without insane complexity & cost.
And method of protection against or able to withstood small overvoltage. (spike as attached description)
I'm also thinking incorporate some inductor, which will improve the PSRR and decrease some rail voltage ? what is the drawback of using inductor in power supply ?
Old 29th February 2012, 01:13 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
A simple resistor and a zener?
LW1DSE
Old 29th February 2012, 01:40 PM   #3
Would you give me typical value of resistor ?
well... zener just get one of correct voltage should be jsut nice.
According to my simulation, it degrades PSRR alot.
Old 29th February 2012, 04:06 PM   #4
Search in any datasheet, the recommended minimum current in the zener under question. Add the load current to it. So, then knowing voltage drop in the resistor, calculate the resistor value and power loss in it. Finally, choose a smaller normal value resistor, and the power of such slowly greater than it. Example: supuose diode current 10mA, load current 50 ma and voltage drop 15V. Then, Ir = 10mA plus 50mA = 60mA.
R = 15V / .06A = 250ohms. Choose 220R.
P = 15V * .06A = .9W, choose 1W.
If the power is not so big, you can also think in a TL431 voltage regulator, that has lower output resistance. But calculus is a bit more complex.
Good luck.
LW1DSE
Old 29th February 2012, 10:52 PM   #5
just to ask, it is wise to only provide regulated supply to non- output stage (output stage using raw unregulated supply), like this I reduce the power (& dissipation) needed to pass through regulation unit. (output use tons of currents)
Through simulation, other than output, the amplfieronly consume 20mA maximum, giving extra 10mA = 30mA.
While output is using about 6A (OMG), I think last time because of that output it got worst PSRR
So here I have attached the link for the choice i would take, so i would like your suggestion on resistor I need :
http://malaysia.rs-online.com/web/p/zener/0812538/
its datasheet : http://docs-asia.electrocomponents.c...6b800297e6.pdf
Just to be sure, in my input stage, I have another pair zener is 15V from ground, I suppose it won't have problems ?
Old 29th February 2012, 11:35 PM   #6
PRR is offline PRR  United States
PRR's Avatar
> I only have my BC550C/560C to use, which is lower Vce. As my rail voltage ... is roughly 27V-28V, I need to lower it to something from 20V-22V to cope for BCs.
BC550 is rated 50V.
http://www.nxp.com/documents/data_sheet/BC549_550.pdf page 2
Yes, 7818 will drop 27V to 18V. One chip one capacitor and maybe a little scrap metal.
Cost; and if you _want_ voltage drop an inductor gives "small" voltage drop.
The raw power line does have spikes. However a well-filtered audio power supply has some transformer resistance and large capacitance. Spikes on the filtered DC are typically VERY small.
Old 29th February 2012, 11:58 PM   #7
nigelwright7557's Avatar
Just buy the right transformer.
Or buy a 5VAC transformer and wire it in series anti-phase with your transformer.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 1st March 2012, 04:36 AM   #8
Originally Posted by PRR View Post
BC550 is rated 50V.
Rated 45V for Vce. The VAS is resposible for full swing, from + to - (mine is dual supply amplifier), so it is exposed to over voltage if maximum swing is over +-22.5V
well.... 18V is a bit out of my limit. Intended for lower limit of 20V. anyway, its more expensive than zener. However, is it better performance than simple zener regulator ? Another question is that, are regulator of same unit able to provide negative voltage without complex ? (For my information, need another regulator that design for minus voltage ? zener just reverse direction then become minus)
Co-incidentally, there are no good transformer at the rate with approx same price, for slightly lower voltage I need. So I just brought the current one. (last time didn't think of anything, then brought a 40V, worst ! ) Also though that slight regulation will increase the clipping and PSRR.
Old 5th March 2012, 01:36 AM   #9
Good luck.
Thanks for your advise, i think it is good for my solution. But I want to consult you about the whole setup. For my case, I'm dropping voltage from 27.4V-28V to 20V using Zener diode. And I get from simulation, the value of usage is 20+mA so for safe assume is 25mA.
so my setup in kinda involve filter/reservoir capacitor(I have some 2.2mF Caps or 1mF is sufficient ?) for 20V rail (regulated by zener) installed after resistor. What should be the value of resistor ? 0.5W 200ohm would doing good job ?
This are the following item :
Old 6th March 2012, 12:43 AM   #10
ChrisA is offline ChrisA  United States
A regulator could work. But don't use anLM7818. Use the 317 adjustable reg and then adjust it to exactly what you want. Use one of those 15 turn trimmer pots to set the voltage. There is a negative version of the 317 also. But these chips will only pass about 1 amp. Is that enough. If not you will need a large size pass transistor and a large heat sink in addition to the regulator. So if this amp needs more then about an amp then I'd just replace the transformer.
Look at the data sheet for the LM317 it will have some good examples of how to do the above.
Also, you could simply use a resistor but I'd take advantage of it and put it to work rather then simply burning off power build a CRCRC" filter, This will not only drop volts but will dramaticaly cut the ripple voltage in the raw power. Not as much as a regulater would but it can handle more amps at lower cost. I'd use the CRCRC for larger currents and the LM317 for a smaller supply.
In the above "CRCRC" the lat "C" is the filter caps you have now, the two "Rs" are resistors to drop voltage use two of them to spead out the heat. the the other two "Cs" can be anything, say 100uF
F5 loaded rail-to-rail voltage? CanAm Man Pass Labs 40 20th March 2011 07:43 PM
How to reduce voltage from PSU?? oblerum Power Supplies 4 10th August 2006 07:04 AM
"reduce rail voltage 20% > pick up on sonics" rick57 Solid State 7 13th April 2006 12:45 AM
Reduce wallwart voltage argonrepublic Parts 2 19th February 2006 02:51 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
