single supply AC grounding question ....
Old 28th February 2012, 02:06 AM   #1
Minion is offline Minion  Canada
Default single supply AC grounding question ....
This is just a quick question .....
I know when building an amp that uses a dual DC supply with a center tap transformer you ground the center tap on the transformer but what do you do with a single supply with a single winding transformer ??
Thanx
Old 28th February 2012, 10:29 AM   #2
DF96 is offline DF96  England
Strictly speaking you should attach the centre tap to the junction of the two smoothing caps. Then you ground the DC output of the supply. This keeps charging pulses away from the ground.
For a single supply you just ground the DC output. So both are the same - ground at the PSU output.
Old 28th February 2012, 10:06 PM   #3
Great ..... Thanx
single supply AC grounding question ....Hide this!Advertise here!
Simple grounding question (separate power supply) sneakers563 Power Supplies 3 23rd January 2010 03:57 PM
Grounding for monoblocks using single external supply GregH2 Construction Tips 0 29th November 2009 08:03 AM
Single ended transformer grounding question Captn Dave Tubes / Valves 1 29th January 2009 05:41 PM
AC/DC power supply question... Yoda Solid State 6 10th August 2001 01:52 AM
