9 volt phantom power advice needed - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th February 2012, 01:35 AM   #1
Smile 9 volt phantom power advice needed
I want to build a 9 volt phantom power box so I can connect an external condenser mic to my PCM-M10 Portable Audio Recorder. I plan on building one based on a charge pump converter described here.
New Page 1
Also, I noticed this DC-DC Voltage Regulator Converter LM2587.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Could this be used to create a 9 volt phantom power source?
I want to record sounds of nature, like a thunderstorm or a babbling brook.
Thanks for any advice.
Old 2nd March 2012, 01:33 AM   #3
Thank you for your reply and sorry for my naive questions, this is my first project. The webench designer tool is great! So I simply input 9 volt and output 48...for Iout should I put 10 milliamps?
Also, how does one compare the chips noise level? Say if my goal is a low noise floor how would I compare the lm2587 to a TPS40210?
DC/DC Controller (External Switch) - Step-Up Controller - TPS40210 - TI.com
And finally, the designs I've tried in the webench call for film chip capacitors. I've never worked with these and am concerned they might be too difficult to work with on a breadboard. Can I use electrolytic capacitors?
Thank you.
48VDC Phantom Power switch - seeking advice CZ101 Analog Line Level 15 9th January 2012 11:12 PM
Power LED from 48 volt phantom power TheFixer Parts 74 16th September 2011 06:00 AM
5U4 Darling power TX advice needed waam68 Tubes / Valves 2 14th December 2008 08:15 PM
Advice needed about Lexsen power - photo attached Brit01 Solid State 2 28th July 2008 10:05 AM
pre / power advice needed! RevF Solid State 3 16th December 2003 12:11 AM
Copyright 1999-2017 diyAudio
