#21 | |
Yes, I can even use one of my big standard EI silicon steel transformer, but it would better to bring down my SG3524 oscillation frequency to 200 hz or 300 hz, because at higher oscillation frequency the Eddy current would be quite high in my output transformer. At those low oscillation frequency the LC low pass filter would need a big L coil, but it would be easyer to keep my SG3524 circuit very stable. Thank Bye Gaetan Last edited by gaetan8888; 24th February 2012 at 08:57 PM. |
#22 | |
This will generate high peak current and huge residues in the output. You do not have to care about eddy current losses: what counts is the flux excursion, translated into volt/turn, and this remains constant. When you increase the frequency without changing anything else, the peak induction decreases in a proportional manner. The situation for hysteresis losses is different, because energy is lost for each cycle, but in practice, this is more or less compensated by the reduced induction level. The only loss that does increase is caused by magnetic viscosity, but it remains relatively marginal. In summary, if you operate the transformer at ~20KHz, you will incur some additional losses compared to 50/60Hz, but that will remain moderate and just requires a small derating.
#23 |
Hello
Another way to do a NFB could be using a small transformer at the output like in my new schematic. I've also done few littles others modifications. Thank Bye Gaetan Last edited by gaetan8888; 27th February 2012 at 03:58 AM. |
#24 |
Hello
I've found the inside schematic of the SG3524. For those who can use it, here it is. Bye Gaetan |
| About a PWM power inverter | gaetan8888 | Power Supplies | 7 | 30th May 2012 05:15 PM |
| Sine Wave Inverter | fortune | Power Supplies | 0 | 18th April 2010 03:21 PM |
| FS:Pure Sine Inverter 300w | rubydac | Swap Meet | 0 | 25th April 2008 04:39 AM |
| modified sine wave power inverter | saltmiser | Tubes / Valves | 3 | 23rd April 2008 05:55 AM |
| switch-mode sine wave inverter design | helenfish | Power Supplies | 12 | 21st March 2006 09:42 AM |
