PS Amp Question - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th February 2012, 04:34 AM   #1
Default PS Amp Question
A quick question, please. If a single-channel amp requires a 40v input to output 160 watts, does the power supply need to provide 2 amps or 4 amps?
Old 1st March 2012, 07:03 PM   #2
You say "amp...output" but do you mean power supply DC watts output or amplifier AC watts output?
It's 80V across + to - so 2 amps for the power suppy to deliver 160 watts, but that's not 160 output from the amplifier output; in real life it depends on the amplifier class, exact efficiency, speaker impedance, and maybe even the nature of the signal material. A conventional power supply may need to supply 10 amps without voltage drop to make a class-A amp put out 160 watts into a low-impedance load continuously. Or a switching-mode supply into a class-D amp only 2.1 amps.
Old 1st March 2012, 07:18 PM   #3
10Apk to 20Apk, depending on how severe the reactance of the speakers and the type of music you listen to.
Certainly not 2A to 4A.
regards Andrew T.
Sent from my desktop computer using a keyboard
PS Audio Question (pre-amp) heiman Solid State 9 18th June 2016 07:00 PM
PS Audio PS Elite Integrate Amp jimmy50 Solid State 14 5th May 2012 06:07 PM
Switch Mode PS question (Chip Amp) Tall Shadow Power Supplies 7 30th October 2007 04:17 AM
Head-amp PS question bm_mode Solid State 5 30th September 2003 02:04 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
Copyright 1999-2017 diyAudio
