Decoupling Single Ended Circuit on Dual Supply - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th February 2012, 03:42 AM   #1
Default Decoupling Single Ended Circuit on Dual Supply
I have a NPN transistor in emitter follower config loaded by a resistor to the negative rail idling at about 100mA. The circuit runs on dual supply, and the emitter follower is further wrapped in the feedback loop of an opamp.
I decoupled the opamp with a single small cap between the rails, and currently have a 100uF electrolytic from collector to ground, another 100uF from the negative rail to ground close to the "cathode resistor".
Intuition tells me that since the emitter follower output stage is running single ended class a, I would just need to decouple from collector to the other side of the resistor. But since its not drawing constant current, I am not so sure.
I would greatly appreciate any comments on how to best decouple the current circuit.
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 35 3rd April 2012 01:19 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Simple decoupling circuit for DACs? eVITAERC Power Supplies 0 23rd November 2005 07:03 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright 1999-2017 diyAudio
