Increasing efficiency of regulator circuit.
Old 12th February 2012, 03:14 PM   #1
zerokelvin99 is offline zerokelvin99  United Kingdom
Question Increasing efficiency of regulator circuit.
Hi everyone.
I'm afraid I'm a bit of a newb when it comes to voltage regulators, but I am trying!! Please bear with me, it's all appreciated
I currently have a PSU unit here that's used for a small equalization circuit.
Here is its current state:
9vAC (well.. 11v) input, into linear PSU, rectified at 13vDC and then into a small regulator design with one zener per rail between 8v-9v (and small electrolytics). Output is consistant with the 0.6v voltage drop, with the +ve rail always being pulled lower by around 0.3v.
SO +ve rail is generally around 7.7v, -ve around 8v.
However, I require the circuit to improve on its lousy efficiency! I planned to run a ±12vDC line in after the rectification but am worried about the Vdrop over the regulators (4v) still causing the power dissipation.
Ideally I would like to run a buck converter from ±12V line down to a regulated ±8v. Is this possible? Otherwise a buck down to ±9v into an LDO reg perhaps? I can't seem to be able to find any DC-DC converters that can do this.
Oh, and finally, the ±12v line is provided by (another) 18-75v buck converter off a battery supply.
Many thanks if you've managed to get this far! Hopefully I've made sense - I've spent too long on this bloody circuit for it to become any clearer to me
THANKS
Old 12th February 2012, 03:19 PM   #2
dtproff is offline dtproff  United States
Standard linear regulator is the easiest.
For a switcher try one of the "simple switchers" from National Semi. Here is to the swicher design tool. WEBENCH® Power Designer Tool | National Semiconductor ? Power Supply Design Tool
Tony
Old 12th February 2012, 03:24 PM   #3
diy didi is offline diy didi  South Africa
Second that! Switchers such as LM2576-ADJ are real easy to use!!
Old 12th February 2012, 03:33 PM   #4
Wow, replies in 5 minutes
Thanks for the link, I'll check it out now!
Old 12th February 2012, 06:05 PM   #5
WEBENCH designer is brilliant!!
So far it seems the optimum design is a LM5576 based design. Input range 30-45v output of 16v. Efficiency of 95%!! Seems to be up on the simple switchers by 6%? The next SS is a LM2592HV-ADJ with a lovely easy schematic
I assume it's okay to split the 0-16v rail into two discrete ±8v rails by means of a potential divider? Or would I need two seperate supplies? One feeding the +ve and one the -ve rail, with the relevant outputs linked for the 0v?
Thanks again
Old 12th February 2012, 07:07 PM   #6
And the LM5576 is available as an evaluation board
Does anyone know about splitting the single rail with a potential divider? I'm getting the feeling it's either an extremely stupid thing to do or a standard way of doing things?
Thanks!
Old 12th February 2012, 07:15 PM   #7
astouffer is offline astouffer  United States
astouffer's Avatar
Thanks!
If you only need low power you can use a chip like the TLE2426. Higher power "splitters" can be made from power op amps like the L165. Both datasheets provide examples.
Increasing efficiency of regulator circuit.Hide this!Advertise here!
Need a little help with a regulator circuit if you are willing. G Tubes / Valves 4 18th October 2011 07:31 AM
Increasing efficiency through output inductor selection zerokelvin99 Class D 12 5th March 2011 08:38 PM
alw regulator circuit boards fmak Solid State 1 3rd December 2008 05:11 PM
help required with regulator circuit please Raj1 Solid State 5 31st January 2004 11:51 PM
Fet regulator circuit HarryHaller Solid State 47 8th January 2003 04:26 PM
