Lithium battery charging mythology?
Old 18th February 2012, 12:45 AM   #41
counter culture is offline counter culture  United States
Originally Posted by BFNY View Post
I would not want to buy your device, or anything else you may design.
Jealousy will get you nowhere.
Old 18th February 2012, 02:36 AM   #42
jc2 is offline jc2
Originally Posted by dtproff View Post
TheShaman;
The MCP part doesn't appear to have a have a thermistor input for a temperature compensated CC/CV charge rate. It is also a linear part. Power dissipation in the IC could be an issue when charging a deeply discharged device.
I would want at the very least some sort of cutoff if the temperature of the cells gets too hot. Ideally you also want to lower the charge rate when temps are below 20C, and lower them further if you are below 10C. But you could get around it with a lower charge rate for all temps
Old 18th February 2012, 12:49 PM   #43
TheShaman is offline TheShaman  Europe
Thanks for the input guys, much appreciated.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 22nd February 2012, 10:43 PM   #44
jameshillj is offline jameshillj  Australia
Thank you gentlemen for your information and for having taken the trouble to post it.
I have just recently delved into this world of UltraFire 18650 batteries with eBay purchases that included really cheap junk chargers and without any real background information, this thread is a very timely reminder to do my homework.
It's back to the old NiMh units until I get all this charging business sorted out - this is no place for ignorance!
Old 22nd February 2012, 11:38 PM   #45
agdr is offline agdr  United States
agdr's Avatar
If anyone has a US source for the Seiko chips, please PM. I tried to find a US source for this lithium balance charger chip
http://datasheet.sii-ic.com/en/batte...n/S8233A_E.pdf
a year ago with no luck.
Thanks...
Old 23rd February 2012, 01:30 AM   #46
dtproff is offline dtproff  United States
Seiko pretty much only sells to ODM's. I sugeest raiding digikey and see what other IC's are available. There is no magic in the Seiko Chip. There are others that work similarly.
Tony
Old 24th February 2012, 02:12 PM   #47
Lorien is offline Lorien
Maybe this will help you!
Cheers, L
Old 24th February 2012, 03:48 PM   #48
agdr's Avatar
Cheers, L
Thanks! I'll give that RFQ a try. They are even here in L.A. - maybe they will do will call.
Lithium battery charging mythology?Hide this!Advertise here!
Charging Lithium ion batteries Diy_Ambitious Power Supplies 11 28th January 2013 06:42 PM
Charging Lithium Batteries Johnloudb Power Supplies 5 21st November 2011 09:55 AM
Novel mode of lithium battery bias mach1 Tubes / Valves 17 4th April 2010 10:29 AM
Digital camera not liking Lithium ion battery xplod1236 Parts 5 21st December 2007 12:17 AM
lithium ion battery tech kaaoszx Everything Else 3 27th April 2007 08:09 PM
