Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th February 2012, 07:22 PM   #1
HiGHFLYiN9s's Avatar
Default Aikido LV Regulator Kit - Choosing the Right Xformer
I recently picked up a gently used Wadia 171i Transport and wanted to build a 9V power supply for it, as the existing wallwart is a noisy one. I selected the Aikido LV Regulator Kit because it can be configured for a 9V output.
LV-Regulator
As stated on the site "The new board is bigger than the H-PS-1 and no longer can accept the voltage-doubler rectifier configuration. But the PCB accepts two possible rectifier configurations (full-wave bridge and full-wave center-tapped). In other words, this regulator can deliver +5Vdc or +9Vdc from two different power transformer secondary voltages; for example, for 9V output either a 10Vac or 20Vac center-tapped transformer secondary; or 5Vdc from either a 6.3Vac to 9Vac or a 12Vac to 18Vac center-tap secondary."
Could anyone recommend a particular transformer from Mouser / Digikey / Edcor or other U.S. supplier for this purpose?
TIA!
My DIY Electronics Blog: DIYAudioBlog.com
Aikido LV improved psu studiostevus Tubes / Valves 24 29th December 2011 03:39 PM
FS: Aikido LV and PSU maxw Swap Meet 1 27th April 2011 09:22 AM
Aikido LV 6N27P SMPS completed sharpi31 Tubes / Valves 5 23rd November 2010 05:21 PM
AIKIDO LV WON'T START wushuliu Tubes / Valves 16 27th October 2010 10:23 PM
Help Choosing Power Supply Voltage Regulator Aikido Phono Amp JustinJ Tubes / Valves 8 20th May 2010 01:55 PM
Page generated in 0.06112 seconds (68.14% PHP - 31.86% MySQL) with 10 queries
