I build this power supply to feed 3 TDA7264 amps (25W+25W each). It is powered by a 250VA toroidal 230 to 17.5-0-17.5 with the ultimate goal to provide 18V. As the LM7818 and LM7918 regulators didn't cover the power I needed (Aprox. 465mA), I went for the LM338 and LM337 regulators and have been having more problems than normally expected. After many rectifications to the design, some burnt components and a couple of minor explosions, I think I finally got it. (see attached PDF's).
I would really appreciate any feedback on the design, flaws or errors I might have missed, ideas, etc. Thanks!! |
#2 |
Hi
First off, 17.5VAC X SQRT2 = 24.7VDC or ~23.7V after rectifier. Loosing 6V in a regulator for a power amplifier, with the product of the current creates significant heating, wasted heat. Awfully inefficient. 18V + 1V(rectifier)--> 19VDC/SQRT2 = 13.42VAC. If you wanted to have voltage regulation, I would not look to drop more than a couple volts. 20VDC supply would need 21VDC/SQRT2 = 14.8VAC. Will each amplifier chip have it's own set of regulators? If not, the LM337 may come up dry on current. A single LM337 supplying 3 amplifiers may need a helper pass transistor.
All the trouble I've ever been in started out as fun...... |
#3 | |
You are also right on the regulators, a single LM337 won't do. Due to my very limited knowledge placing a set of regulators on each amplifier seems easier than setting a helper pass transistor (had to look it up and just learning about it). Again, thanks a lot for you knowledgeable response!! |
| Pair. Toroidal 250VA, 60Hz, 24V transformers | tweakk | Swap Meet | 1 | 29th December 2011 11:18 PM |
| FS/FT: Avel 250VA 2x35v | Arc | Swap Meet | 4 | 20th December 2008 03:37 PM |
| Not polarized electrolytic capacitor in power supply (LM317 LM337) | ygg-it | Power Supplies | 5 | 19th October 2008 07:25 PM |
| 33000 uF capacitance on input of LM338 regulated supply for LM3886 | bikehorn | Chip Amps | 3 | 7th July 2007 09:47 AM |
| 250va? | bbksv | Chip Amps | 11 | 1st February 2004 06:58 PM |
| Page generated in 0.08012 seconds (70.26% PHP - 29.74% MySQL) with 11 queries |
