Question about transformers?
Old 5th February 2012, 09:30 AM   #1
harmonicconverger is offline harmonicconverger  Philippines
Default Question about transformers?
i have 29-0-29 volts transformer. i'm from philippines. our voltage from outlet is 220v, but i have this large transformer with 100v labeled in the primary. can i use 110 to 220v converter?
one more question. i have this another transformer with black, green, yellow, white and red color leads. can you tell me what this color codes stand for?
Old 5th February 2012, 09:38 AM   #2
Default picture.
here it is.
i think it is 110 to 220 volts converter. but the leads are confusing.
Old 5th February 2012, 02:07 PM   #3
GloBug is offline GloBug  Canada
Banned
Do you have a multi-meter? (DMM)
Old 5th February 2012, 02:10 PM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
How much power are you trying to employ from the final transformer ?
Looking at the photo I think you would be better off buying a new transformer.
Old 5th February 2012, 02:23 PM   #5
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Yes I would think you could stand to get a replacement for this transformer.
Look at where the wires are coming from....those holes in the four corners are suppose to have nuts & bolts squeezing the lamination stack together,
If you have a choice, get a true 220-110? step down transformer.....The bulk of the 'conversion transformers are what's called "Auto-Transformer"s.
Try to get a "true" transformer with both Primary and secondary windings, not the common windings of an Auto-Transformer.
__________________________________________________ ________Rick.......
Old 5th February 2012, 02:25 PM   #6
Are you trying to replace it or just use it ?
Old 6th February 2012, 12:28 AM   #7
it has a cover. i thought that if i will remove the cover i will got the primary and secondary winding. but that is what I've got. step down transformers are expensive here. i just want to use it for my 100 volt amp.
Old 28th February 2012, 04:28 AM   #8
FRANK BRAUN is offline FRANK BRAUN  Philippines
You can use a 220v to 100v (and not the common 110 v out) auto transformer. If you are using it for audio (obviously since you're on DIY audio), consult the power rating of the audio product on the back label and note its power rating in watts. Your converting transformer should be larger than the rated consumption. Try getting a 100 v output converter if you can, doing math you will get approx 5-10% higher voltage on the secondary if you use the common 220 - to - 110 converter.
YOU CAN USE approx. 500- w converter to be safe.
PS. Don't use PC AVRs w/ 110v outlets they're for low wattage consumption only!
Old 14th March 2012, 02:12 AM   #9
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
agreed, they are completely useless....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Question about transformers?Hide this!Advertise here!
Question about toroidal transformers 00940 Power Supplies 15 19th February 2009 03:21 AM
Question about chip amp with different type of transformers??? Leolabs Chip Amps 3 5th September 2007 07:30 PM
Question about matching impedances and transformers. JoeBob Parts 3 29th November 2004 12:49 AM
Transformers and other Newbie question NaftaliG Chip Amps 1 19th July 2003 07:36 PM
quick question on transformers SQ Kid Chip Amps 5 24th April 2003 10:05 PM
