Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th February 2012, 08:07 AM   #11
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
this is pretty good now, you could find out, where you loose most of the power
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 9th February 2012, 08:09 AM   #12
PChi is offline PChi  United Kingdom
Default Thanks for the update.
I wouldn't be ashamed, getting anything to work is hard. I worked on a vehicle system where the voltage drop down between the battery and the inverter was about 2 V until it was rewired.
I think that the efficiency looks quite reasonable.
I'm not sure of your circuit but at 6.12 A the SR5100 is a little ungenerous. I have looked at a data sheet from MOSPEC and the forward voltage is curving up beyond about 3 A. It is typically 0.7 V at 5 V according to the graph. So higher current rated schottky diodes might gain a little improvement.
At high currents I have had success making high current transformer windings with copper strip.
Old 9th February 2012, 05:42 PM   #13
dtproff is offline dtproff  United States
Congrats on the efficiency. Rule one is always check the fuses (meaning check the simple stuff first).
Good job.
Tony
Trafo bad, or am I bad caxxxxxx Chip Amps 24 3rd May 2011 08:56 AM
smps 12v inverterhello i am new in this forum , excuse my english it's very bad i mineralman Power Supplies 0 8th February 2011 10:09 AM
Dragster Amplifier bad SMPS ben12345 Car Audio 38 4th February 2010 03:22 PM
Efficiency jerryo Multi-Way 0 18th May 2009 07:37 PM
2.5 way efficiency michael Multi-Way 20 25th December 2003 05:18 PM
Page generated in 0.06256 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
