Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th February 2012, 12:02 PM   #21
Tenson is offline Tenson  United Kingdom
I've seen this schematic to get 3-pin regs working with higher voltage but I'm not sure how to apply it correctly in this design.
http://www.national.com/ms/LB/LB-47.pdf
Old 9th February 2012, 12:21 PM   #22
That type of regulator drops most of the voltage before it hits the regulator.
Its pretty much a fixed output, you can't adjust it to low voltages.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 9th February 2012, 12:37 PM   #23
KatieandDad's Avatar
Why not Pulse Width Modulation.
Its easy to implement.
Do you want a circuit with feedback (ie self controlling) or are you happy to adjust the speed by hand?
If its the latter you can just use an NE555 driving a MOS-FET to provide HT voltage pulses to the motor.
The beauty of PWM is that you will get higher torque at low speeds than you would with simple DC voltage control.
Old 9th February 2012, 12:42 PM   #24
Originally Posted by sawreyrw View Post
sreten,
You don't regulate the output of a voltage regulator by having a regulator
with a negative output resistance. This is nonsense and could easily lead
to oscillations in a real system. The only reasonable way to do this is to
use a feedback loop that senses the output and applies a correction signal
to adjust for any changes in the output.
The only person talking nonsense for this application is you.
Of course a voltage regulator with negative output impedance
no longer regulates voltage, that is the point. It regulates
the virtual voltage across a virtual winding with no series
resistance, giving constant speed characteristics.
Any real system with feedback (including normal regulators)
will oscillate if designed wrong, your stating the obvious.
As the virtual point is not accessible for feedback, a small
series resistor between the load and ground is required
to provide a voltage proportional to current for feedback.
The feedback needs to be mixed to get the negative impedance.
Variable Amplifier Impedance
Figure 3 - A Negative Impedance Amplifier
(the floating input looks very awkward, not the best example)
Your "only reasonable way" is simply a regulator and
won't maintain near constant speed as I've described.
What is needed is like a single rail power amplifier
with no coupling capacitor and a single ended output.
That sounds like one rail of regulated amplifiers power supply ....
But with a lot more heatsinking and devices depending on the
voltage and current range you want to support for the motor ....
rgds, sreten.
Old 9th February 2012, 12:52 PM   #25
rgds, sreten.
Really? I got the impression it was adjustable from 1.2V to 160V.
Old 9th February 2012, 02:44 PM   #26
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
The output of the transistor pre-regulator tracks the output of the 317 reg so the output can be set at a wide range of output voltages. You just have to scale up the pass transistors as the app note used low power devices.
The circuit could work with the one I posted but you will have to adjust component values around the feedback paths to have enough range for the amount of torque boost needed.
Old 9th February 2012, 02:46 PM   #27
darkfenriz's Avatar
Sreten,
Although I can agree you have some merit here with a clever circuit, this is usually not needed and if it is, the speed control of some sort is used.
Transcriptors DC Rotadrive DC Motor Kit Transcriptors Vendor's Bazaar 0 6th December 2009 10:08 PM
Variable DC power supply to drive TT motor IZHAKKATZ Analogue Source 9 9th April 2009 08:33 PM
Hard drive motor as a bearing YAKI Analogue Source 3 3rd March 2009 08:17 PM
Floppy drive motor BluesMagoos Analogue Source 20 13th June 2007 05:56 PM
How do I drive volume motor? Prune Parts 7 9th July 2004 01:34 PM
Page generated in 0.09310 seconds (77.18% PHP - 22.82% MySQL) with 10 queries
