#41 | |
Yes in one of the common LM3876 PSU designs used, including the one you posted, you could simply connect together separate secondary windings on these to create a center tapped secondary. Yes it is certain it is capable of 24-0-24 VAC output, which through a bridge rectified typical PSU circuit like you posted, would give roughly +33/0/-33 VDC output to the amp. Last edited by !; 3rd February 2012 at 07:50 PM. |
#42 |
A dual secondary transformer has two secondary windings. They are isolated from each other.
You can use the windings to do different and independent jobs. Or you can join the two windings together. Here's the difficult bit and why I asked "parallel?" You can join the two windings together and blow yourself up. Or you can join them in parallel or in series. Do you yet know the difference between series and parallel? I want you to understand that working with mains is potentially lethal. You must be able to convince us that you know how to keep yourself alive, then we can lead you safely down the garden path. So I set a test. You explain to us what series windings means and explain what parallel windings means. From your answer we can judge what level of assistance you require.
regards Andrew T. Last edited by AndrewT; 3rd February 2012 at 08:44 PM. |
#43 |
^ and use that light bulb current limiting circuit you often recommend (AC mains input to amp has an incandescent light bulb wired in series on the AC hot conductor).
#44 | |
Thanks to all you guys for your assistance. I'm attaching the latest version of the schematic. This has on it changes we have discussed, and I also adde alpha-numeric designators on the resistors and caps. I think (and HOPE) everything's right this time. Now one more question. I'm ready to put up the preamp schematic. Do I put it here, or start a new thread? Thanx The Happy Hippy
#45 |
I was hoping for series saying something along the lines of the current through the first windings passes into the second winding.
Does that help confirm what you are thinking? A dual secondary can be converted to a centre tapped secondary by joining the two windings together in series. The voltage of the two windings adds up, when wired correctly to measure double the voltage. That's where your ref. to 48Vac came from. It is also the way you can check you have wired it. You should be able to measure the two winding voltages at slightly more than 24Vac for each. maybe 25Vac to 26Vac each. The series windings should then measure about 50Vac to 52Vac. But before you plug anything into the mains build that bulb tester mentioned by !
regards Andrew T. |
#46 |
I was thinking you would say something about the primary - the schematics posted, such as in #44, don't show the primary the way it's shown on that transformer's datasheet. Connecting it wrong can make the bulb tester glow at full brightness, but at least that's better than wondering why the fuse blows every time the unit is turned on.
#47 |
#48 |
OK the preamps now posted under the chip-amp subforum.
#49 |
| Power supply positive-negative-ground from a single power supply | mome | Power Supplies | 8 | 9th September 2011 05:17 PM |
| Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. | tweakk | Swap Meet | 3 | 23rd February 2011 06:46 PM |
| LM3876 for guitar? | Wynand | Chip Amps | 4 | 2nd November 2005 08:26 AM |
| Lm3876 | bobossa | Chip Amps | 1 | 1st March 2005 04:18 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.13144 seconds (75.24% PHP - 24.76% MySQL) with 11 queries |
