Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st February 2012, 05:56 PM   #31
DF96 is offline DF96  England
Do Chinese factories worry about EU PFC regulations?
Old 1st February 2012, 05:59 PM   #32
AndrewT is online now AndrewT  Scotland
Do Chinese workers bother with any regulations?
regards Andrew T.
Old 1st February 2012, 06:09 PM   #33
S.A.G. is offline S.A.G.  Italy
don't get me started on this...
Old 2nd February 2012, 06:54 AM   #34
Rodeodave's Avatar
Scope is not clipping, the waveform looks the same on the secondary of a 15VAC transformer. Plus the probe is attenuating 10-fold.
EN50160 allows for 8% THD, see here for example: http://www.evu-messtechnik.de/docs/E...EN_50160-i.pdf. The individual harmonics must not exceed 5% for 3rd, 6% for 5th, 5% 7th and so on.
Meanwhile the engineering guy replied, and he offered to get a measurement done at the house connection, with the power company covering the costs. This shall be interesting.
Gravity - Making the G since 13.7 billion B.C.
Old 2nd February 2012, 12:58 PM   #35
dtproff is offline dtproff  United States
OK... that takes care of my stupid ideas. Let us know how this turns out.
Tony
Old 2nd February 2012, 03:44 PM   #36
Rodeodave,
I've checked the standards and it turns out that you are right on the EN 50160 8% THD, the 3% number is from MIL-STD-1399 Type III (400Hz). OOOOOPS, sorry for the confusion.
Good to hear that the power company is taking care of your issue.
Old 2nd February 2012, 05:10 PM   #37
Here's what the mains look like in a residential area outside Raleigh, NC, USA. The larger trace is from Line to Ground, at 50V/div. The smaller trace is from Neutral to Ground, at 1V/div. This second trace is showing the voltage drop on the neutral line from where it is bonded at the distribution panel, to this outlet, which effectively represents the current on this branch circuit.
The loads are a 1000VA UPS serving one PC and the usual peripherals, a small studio amp playing music at low level, a 20W fluorescent light fixture with electronic ballast, and the scope itself.
I doubt that flattened peaks are all that unusual, for the reasons already explained.
Old 2nd February 2012, 05:11 PM   #38
zigzagflux's Avatar
I don't know that there is much they will (can) do for you. As has been explained (and partially ignored), this flat topping is typical, and not at all abnormal in today's electronic world without power factor correction (electronic control system that forces current draw as a sine wave).
At best, they could install a larger transformer to reduce the source impedance. Voltage drop across impedance at the peak current is the root cause. This is a result of ohm's law. You don't filter it out; there is no defective equipment. It is expected.
A larger transformer will still exhibit some flat-topping, just less extreme.
Can a Filtered IEC Power Inlet Improve Sound Quality? Haz Power Supplies 9 30th January 2011 06:24 PM
Commercial Mains Filters - Good or bad idea? hifinerd Power Supplies 2 12th September 2010 11:14 AM
mains quality variation Professor smith Solid State 36 13th July 2010 01:03 PM
Jamicon Capacitors - will replacing them improve sound quality? guitarobert Instruments and Amps 9 6th December 2006 11:48 PM
Page generated in 0.09673 seconds (78.76% PHP - 21.24% MySQL) with 11 queries
