Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd February 2012, 11:46 AM   #21
Puffin is offline Puffin  United Kingdom
Well, well, well. Just shows you that the tools you value the most can let you down when you least expect it
The voltage is fine. My DVM has gone tits up!
A mate came round today and I mentioned the problem to him. We went and listened to some music and checked the incoming mains on my Belkin. Came back and checked with DVM. 330vac.
Tried and another DVM and it was 246vac. The rest is history
I love a happy ending. Thanks to all for your input.
Rob.
Old 2nd February 2012, 07:53 PM   #22
effebi is offline effebi  Italy
effebi's Avatar
I had similar problems once with a cheap meter.
It was only the (very) low battery.
Old 7th February 2012, 09:12 PM   #23
I am finishing off the case for the dual PS. I added an LED for each PS. Each PS is exactly the same. DC voltages are a very stable +38-0 -38 for each PS. However when I switch it off one LED takes about 3 times longer to fade (the first one to fade takes about 40 seconds)
Any ideas anyone?
Rob.
Old 8th February 2012, 12:55 PM   #24
Up-date. Both LED's fade at the same rate when the PS is under load. I have now finished the enclosure for the amp which includes a speaker protection circuit. I have added a suitable transformer for the speaker protection with the dual PS for the amps, which is wired to the ac inlet.
With the bulb tester the 2A fuse is fine. Without it blows. It will blow a 3.15 fuse as well. When using the bulb tester it will glow very brightly and then dim, even if it is switched on and off after a few minutes. Should I use a CL60 on the mains inlet?
Old 8th February 2012, 04:32 PM   #25
A CL60 on the main PS feed has done it. No more blown fuses. I suppose with a total of 80,000uf (both boards) it needs it.
SMPS with split rail output for Class D? eem2am Power Supplies 1 30th June 2011 11:22 AM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
split rail supply obtain from a single motorcycle battery? leinahtan Power Supplies 5 30th August 2006 05:56 AM
basic split rail PSU mcai7et2 Solid State 6 30th January 2003 11:10 AM
Page generated in 0.26176 seconds (26.36% PHP - 73.64% MySQL) with 11 queries
