Power supply cap multiplier with electronic protection
Old 16th April 2012, 03:05 PM   #11
dadod is online now dadod  Croatia
dadod's Avatar
Originally Posted by sawreyrw View Post
I don't think the overload and short circuit will be fast enough to protect the supply. Also, I doubt the pass transistors can handle 10 amps without overheating. I could be wrong; have you done a worst case thermal analysis? I don't see any voltage reference in the schematic. How do you think this will regulate if the input line voltage changes?
Here is simulation at cca 10 A of the load current. There is about 5 V of the voltage drop on the regulation transistor and with 10 A it gives 50 W. Look here for SOA http://www.onsemi.com/pub_link/Colla...MJL4281A-D.PDF
This is not a stabilizator but regulator or some kind of a capacitor multiplier. It will follow slow input voltage changes, but regulate a fast ones.
dado
Old 30th April 2012, 08:09 PM   #12
dadod's Avatar
Originally Posted by dadod View Post
LineSource, did you do any simulation, what do you think of the regulator??
This regulator (BJT type) is used in my TT amp and works as intended.
dado
LineSource, I was expecting to get some information from you but nothing, it's not nice that. Have you done your simulation and what is your opinion?
dado
Old 20th October 2012, 01:20 AM   #13
jameshillj is offline jameshillj  Australia
dadod, just saw your thread linked from other one - late, as usual!
What does all the circuitry around Q6,7,8 &9 actually do, including the zeners D7,8,9 on the +ve rail (similar to -ve rail) - if this can be either simplifier/left off, it's a much simpler cct and I might try it out.
... james
Old 20th October 2012, 02:10 PM   #14
dadod's Avatar
... james
Q7 and Q8 act as “thyristor” circuit, they are normally off, but if an input voltage is applied to Q8, even briefly, it will conduct and feed current into the base of Q7. This will make Q1 conduct, which in turn, will feed current into Q2, which holds the circuit on, or latched.
Q9 is the loudspeaker protection sensing element, and the zeners define that what difference in supply lines are acceptable, in this case if differente is more then 20 V it will trigger protection and cat the power. This will happen if one of the supplies is cut off, and it will then turn the other line off as well.
dado
Old 20th October 2012, 04:54 PM   #15
dadod's Avatar
Last PCB layout is here. ThermalTrak+TMC amp
Old 6th June 2013, 05:02 PM   #16
franzm is offline franzm
Q7 and Q8 act as “thyristor” circuit...
Also does the Naim supply regulator.
Old 13th September 2013, 09:45 AM   #17
dadod's Avatar
Thanks for information, I didn't know that
Old 26th April 2014, 11:42 AM   #18
R.I.P.
Is post1 schematic the current version, or is it superseded by post 15?
regards Andrew T.
Old 26th April 2014, 07:57 PM   #19
dadod's Avatar
Actually I made an improved version and I use it now with my TT amp. If you are interested I can show it in my TT amp tread with new layout.
Old 6th July 2014, 04:08 PM   #20
mcd99 is offline mcd99  United Kingdom
Hi Damir,
This is a nice solution to a problem I have been trying to solve with my latest amplifier. Could do with higher voltage rails but I suspect this can be easily achieved.
Do you have a latest version or is the version in your TT amp thread the final solution?
Paul
Power supply cap multiplier with electronic protectionHide this!Advertise here!
why this class D power supply no high voltage side electronic cap? greenamp Class D 10 29th January 2012 05:32 PM
Voltage multiplier vs transformer for preamp HV power supply frickecello Tubes / Valves 1 23rd February 2011 11:24 PM
Problem with capacitance multiplier power supply jscherer Parts 15 22nd March 2009 02:08 PM
Capacitance Multiplier Power Supply Redshift187 Chip Amps 5 15th January 2009 12:34 PM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
