Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th January 2012, 06:21 AM   #1
Default sourcing out small transformers
hi guys,
i'm working on an electronic crossovers and have replaced the op-amps in the audio section.
since the new op-amps were installed (lm4562), it is still working perfectly.
but i know the lm4562 draws current far more than the stock ones ba4558,ba4560, i want to upgrade the small transformer in the supply section.
however i tried searching the web but couldn't find any info on what they are specifically called and were to purchase them. they look like the one pictured below. the one labeled 3540100.
the diodes (1 zener, 1 1n4934) beneath it reads 25.7vdc before entering the transformer. then after the transformer, before entering the diode, it reads 13.7vac. can't read anything with my dvm set to DC. then after the diodes, i get the +/-15v for the op-amps.
where can i get one with higher rating, and what other specs should i be looking/be concerned with?
thanks
Old 25th January 2012, 08:16 AM   #2
There's no reason to upgrade anything unless you're pulling enough current to burn that LT1072 out, and it will be the first to go, not the transformer.
Old 25th January 2012, 04:25 PM   #3
ok, thanks. when i had the ba4558 and ba4560, the supply pins read +/-15.17v. With the lm4562 in place, it dropped down to +/-14.96v
thanks for the heads up. but for future projects, can you lead me to a website where i can find more info about this small transformers? i wanted to at least get some knowledge about them.
thanks again.
Old 26th January 2012, 07:41 AM   #4
thanks again.
That voltage drop is well within the normal voltage regulation of small flyback or forward converters, you might be able to pull it all the way down to 14 volts before you notice anything overheating.
As far as small ferrite transformers go, the fundamentals are unchanged. however due to the very small core you'll need a lot of turns and leakage inductance is rather high.
here's a link that might help you out.
2001 Magnetics Design Handbook - MAG100A
Old 27th January 2012, 12:16 AM   #5
ok johansen, noted everything. will be checking out the link.
thanks for all your help.
SMALL SIZE OUTPUT TRANSFORMERS el156 Tubes / Valves 17 10th November 2010 12:46 AM
Sourcing Small High-End Coaxial lucadelcarlo Multi-Way 17 11th July 2009 06:14 AM
Triad isolation transformers?....the small audio ones redrabbit Parts 1 24th December 2007 02:30 AM
PTC resistors for protection of small transformers roffe Parts 2 15th November 2007 01:03 PM
small transformers? CRFX Chip Amps 16 7th May 2004 04:02 AM
Page generated in 0.07818 seconds (74.07% PHP - 25.93% MySQL) with 10 queries
