can't get my head around PSU's, help choosing.
Old 24th January 2012, 10:20 AM   #1
gafhenderson is offline gafhenderson  United Kingdom
Default can't get my head around PSU's, help choosing.
can someone tell me what size power supply i would need to run these from?
Product Number
AA-AB33182
Product Name
4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board
for subwoofers.
10-32v input
Product Number
AA-AB32181
Product Name
2*100 watt @ 4ohm TK2050 Class-D Audio Amplifier Board
speakers.
10-30v input
would this work well?
eBay - The UK's Online Marketplace
thanks for your help.
Old 24th January 2012, 11:04 AM   #2
runebivrin is offline runebivrin  Sweden
runebivrin's Avatar
Send a message via MSN to runebivrin
Should work OK. But you won't be able to drive all those amps at full power with just one PSU; there's not enough current available. For normal use with music you shouldn't have a problem.
Do wizards use spell checkers?
Old 24th January 2012, 11:11 AM   #3
yes, that PSU will power the amplifiers.
You may need to add some filtering between PSU and amp PCB.
Are you aware that these are not 100W amplifiers?
Each amp is more like a 30W to 35W specification when run on 30Vdc.
On 24Vdc they will be considerably less.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th January 2012, 11:21 AM   #4
i was planning on running each module from its own power supply, i'm just completely confused as to what i'm looking for. i read a link on making your own specifically and it messed my head up for hours of reading the same article over and over again.
care to expand? especially the filter part?
4 Channel 100W TK2050 D class Audio Amplifier Board Assembled | eBay
as far as i was aware these were internally bridged amp modules.
thanks for the replies.
Old 24th January 2012, 11:28 AM   #5
Don't try to build an SMPS.
Either buy a ready made SMPS or build a linear PSU.
Yes, the chipamps can be bridged.
I have never used an SMPS to power a chipamp, I can't tell you what might need to be added. Just a forewarning.
regards Andrew T.
Old 24th January 2012, 05:44 PM   #6
Kay Pirinha is offline Kay Pirinha  Germany
100 watts @ 4 ohms means a voltage swing of 56.6 Vpp. Even in bridged mode you can't expect this voltage swing from only 24 Vdc, no matter if, or how you expand filtering. You will need a DC supply of at least 33-35 V for bridge mode, or 65-70 V for a single power output stage.
Best regards!
Old 25th January 2012, 08:11 AM   #7
But, they are not 100W amplifiers.
The specification shows 30W @ sensible distortion.
The higher powers are shoving out squared off sinewaves.
regards Andrew T.
can't get my head around PSU's, help choosing.Hide this!Advertise here!
Head to head comparison of Manger and Lowther in Acousta and Front horns David Pinnegar Full Range 3 12th January 2011 12:59 AM
motor types head to head for a TT p_ete2003 Analogue Source 20 11th January 2007 08:29 PM
PSU's for CDM PRO2 simon dart Digital Source 7 29th November 2005 05:12 PM
psu's odysseybmx414 Chip Amps 16 26th November 2005 07:13 AM
Copyright ©1999-2017 diyAudio
