greeting everyone,I have positive regulator I.C LM 7812 need to boost output current around 2 ampere.How to add transistor to get that current.I don't want to use 317 series,can anyone please give me simple circuit to wirring will very appreciate ( I use this I.C regulator to heat 12AX7 filament it work fine and sound good enough for my ears but I need more current).Thanks foward.
#3 |
#4 |
This works well. I have built it.
![]() I have used BD139 for Q1. Full information here http://www.extremecircuits.net/2009/...r-circuit.html http://www.extremecircuits.net/p/com...-projects.html Last edited by Puffin; 18th January 2012 at 07:00 PM. |
#5 |
#6 |
#7 |
#8 |
Look up some 7812 data sheets. I can;t say for all of them, but some will have basic sample circuits, one of which will be that current boost.
Meanwhile, a 12AX7 at 12v needs 150ma. How many 12AX7s do you have to need 2A for them? |
#9 |
thanong -
Can you give us a bit more information? Specifically, What is this being used in? What is your voltage supply? (What transformer, rectification, etc...) What is the load? You mention filaments, what kind of tubes? How many? You say you want to 'boost the current' Can you elaborate?
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
| constant current boost converter | djQUAN | Power Supplies | 5 | 12th October 2009 09:39 AM |
| STK4050V current boost | longthrow | Chip Amps | 3 | 24th September 2009 01:03 PM |
| [enquiry] Treble Boost/High frequency Boost circuitry | elnino86 | Parts | 2 | 18th December 2008 12:33 PM |
| 317/337 with current boost | jaudio | Power Supplies | 2 | 19th January 2007 06:42 PM |
| current boost lm317 prob. | deepanger | Solid State | 15 | 7th October 2004 06:52 AM |
| Page generated in 0.17564 seconds (50.98% PHP - 49.02% MySQL) with 10 queries |
