I'm looking for 2 x 47uf or 1 x 100uf/450V PS filter cap to replace the std 1 x 47uf/450 electrolytic Illinois cap in my Fender Pro Junior guitar amp. I'm thinking of F&T electrolytic caps because of their compact size (21mm OD x 35mm L) but also my impression that their quality as a bit better than the run of the mill electro.
Is this impression justified? Is there anything better around with a similar physical size? Nichicon VX any better? The quality Nichicons, Elnas, slit-foils etc don't seem to go to 450V. Another thought is to remote mount some larger Solens or Jantzen Crosscaps-would it be worth the trouble? |
#2 |
There is Mundorf and Jensen but at much higher cost.I would get the F&T.
#3 |
If you can afford I will go for these ASC oil filled MKP model X386S 440VAC
http://www.ascapacitor.com/pdfs/products/X386S.pdf ![]() Nichicon KX series also good but are lytics (less quality) but price is more economical, available at Mouser: http://es.mouser.com/Passive-Compone...con+kx&FS=True Last edited by merlin el mago; 16th January 2012 at 04:07 PM. |
#4 |
Dufus, do you mean the Mundorf MLytic 50+50/500V? Would they be an improvement on 2x single F&T 47uf/450V? The size of 35mm x 50mm is good. I read somewhere that F&T actually make the Mundorf caps-any confirmation on this? The size and specs from the data sheets below are identical.
Mundorf M-Lytic HV Capacitors F&T Can Capacitor 50µF x 50µF / 500V Merlin, I didn't think the KX come in 47uf/450V but I will check. As to the ASC caps I would love to fit these but they are absolutely huge (63mm x 115mm) and I would have to mount 2 of them remotely somewhere with long leads and would take up alot of air space in the small 10 inch speaker cabinet. Nevertheless is there any problem with using long leads to remote mount large capacitors?
#5 |
The F&T should be clear improvement over stock cap.If you want to spend more get the Mundorf.
You can't go wrong. |
#6 |
Thanks Dufus.
#7 | |
LKX2W560MESY25 Nichicon Aluminum Electrolytic Capacitors - Snap In |
#8 |
Yes thanks Merlin, I would have to use 1x 100uf KX.
Is this the correct order of excellence (and size!)? 1. Continental A cap 2. GE motor start 3. ASC X386 4. Solen, Jantzen etc polypropelene 5. MLytic 6. F&T, JJs etc 5. Nichicon KX 4. Nichicon VX 5. Xicon 6. Illinois |
#9 | |
#10 |
| want opinions on caps | thetube0a3 | Chip Amps | 5 | 10th February 2010 01:31 PM |
| Ps. Caps For Parasound New Classic 2125 Amp | crippledchicken | Solid State | 2 | 11th April 2008 04:42 AM |
| Paralleling small value caps with large value PS caps | xyrium | Power Supplies | 16 | 14th October 2005 04:06 PM |
| ps bypass caps on sub plate amp? | crippledchicken | Solid State | 7 | 27th January 2005 09:46 PM |
| PS Audio Power Director experiences/opinions? | dc | Everything Else | 0 | 8th July 2002 06:00 PM |
| Page generated in 0.15920 seconds (63.78% PHP - 36.22% MySQL) with 10 queries |
