Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th January 2012, 08:51 PM   #1
Default Stabilising SMPS simulation for Amp supply
Hello, please could you help to stabilise my LLC SMPS simulation.
Its got a split output so it can be for a half-bridge class d amplifier. (330W)
Its in LTspice.
I have made it have a minimum frequency by adding a current source I1 to the LTC6908.
I then implemented variable frequency by adding a PNP transistor to the frequency changing parts of the LTC6908.
It doesn’t seem possible to stabilise it, so I am hoping that you may assist me.
Here is the LTspice simulation in .txt form, and if you make it to .asc form, then it will be runnable in LTspice
2shared - download LLC.txt
Here also is simulation
LLC.txt
Old 15th January 2012, 06:16 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Any particular reason you're using a pure oscillator IC instead of a purpose-built LLC controller?
Old 15th January 2012, 06:18 PM   #3
yes, linear.com dont have a model for an LLC controller
Old 16th January 2012, 04:59 AM   #4
dtproff is offline dtproff  United States
I will be honest ant tell you I have never been able to stabilize the LLC in either symetrix or ocad. From what I understand from talking to the resident PHD here, this issue is in the small signal model for the LLC's is not well described for a spice simulation because of the way Lp/Lr add in over the power range. Not sure I am in total agreement with him but he does have the PHD in his tittle and he heads up the advance R&D group.
If you just want help stabilizing the loop for the LLC using a standard TL431/Opto I can certainly provide you some values that will get you pretty close the first time up.
Tony
Old 16th January 2012, 05:15 AM   #5
Alternatively, if you just need the open loop waveforms yuo could set it to resonance and see what you get.
Tony
NEWBIE - POWER SUPPLY SIMULATION PROBLEM obiwankenobi Software Tools 1 27th July 2011 05:19 PM
smps spilt supply arisoaris Power Supplies 13 16th January 2011 01:07 PM
Need help stabilising PSU NinjaKitten Power Supplies 3 16th May 2009 04:30 PM
power supply pspice simulation problem metebalci Tubes / Valves 9 10th August 2004 01:59 PM
Page generated in 0.07848 seconds (73.34% PHP - 26.66% MySQL) with 11 queries
