I have a transformer I bought off a guy from an abandoned kit. It measures 17-0-17 on the CT winding (& 6.3-6.3) but the resistances on the CT seem funny as I get 2.99 Ohms on the 17-17 and 2.23 on either the 17-0 or 0-17 when expecting 1/2 of the 3 Ohm full winding value. All I can think of is that there is an about .75 Ohm resistor in series with the CT.
Has anyone else seen this? Is this difference typical for CT transformers? If I unpeel the wrapping will I find a resistor hidden in the works? TIA Carl |
#2 |
What if you measure resistance with both probes from the same end of one winding? I'm wondering if your meter and/or probe contact is adding some resistance to the measurements.
#3 |
Good point, I cal'ed the 3468 last week but didn't recheck the short circuit probe resistance when I made the measurements above, tho I think from last week it was around .1 Ohm. I'll check & report back. If you're right I should see my mysterious extra .75 Ohms on the leads and connects.
#4 |
Before you can measure anything you need to learn how to use your measuring instruments.
This applies to anything, from a 12" ruler to an MRI machine.
regards Andrew T. |
#5 |
For measuring low resistances you really need the 4-point method. That avoids measuring the contact resistance too.
#6 |
Is this the Kelvin connection?
regards Andrew T. |
#7 |
Kelvin sensing?
| problem with old Sony PS-LX510 linear-tracking turntable -- mechanical question | Pickngrin | Analogue Source | 20 | 22nd July 2010 03:19 PM |
| Question about CT transformer and Brian's Rev C power supply board | maurycy | Chip Amps | 9 | 8th December 2009 09:21 AM |
| transformer with ct or non ct? | galih | Chip Amps | 7 | 7th December 2009 05:08 PM |
| Linear PS help | ashley_kitty | Power Supplies | 2 | 16th May 2007 12:00 AM |
| Need help with linear PS | tonyptony | Power Supplies | 33 | 14th April 2006 09:37 AM |
| Page generated in 0.08013 seconds (75.55% PHP - 24.45% MySQL) with 10 queries |
