Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th January 2012, 03:30 PM   #1
kees52 is offline kees52  Netherlands
Default samsung P58 supply for apple powermac G4
Hi there
I have a dead supply, when testing for starting I see a little tryout for start, only the high amperage lines are off, the 25 v and 5 volt are present.
put start to low level, green wire to low level it do nothing except a small tryout of 100 mv.
there is a fast diode in series with the drains of two mosfets, there I measure 56 volts between kathode and anode of that diode, that is a little high is,n it?
diode see the attachment.
Old 13th January 2012, 07:09 PM   #2
Hi All
the supply do work again.
replace C135 and C137 56uF (I did 100uF and works) and C141 47 uF all 35v she are beneath the mosfet sink, on the primary site, also check output caps for leakage and capacity.
sometimes the primary cap 360uF 420 volts are defective and open, this will blow the mosfets switch transistors.
so you with a G4 mac, these wil do repear the supply.
regards.
WTB: Samsung 512N internals (power supply and VGA board) vroomx2 Swap Meet 0 8th January 2005 07:26 AM
sound input into iBook G4? jkratz Instruments and Amps 11 18th June 2004 04:06 AM
Page generated in 0.08125 seconds (63.92% PHP - 36.08% MySQL) with 11 queries
