This is an old style core lamination plate. The center tap is bended in order to insert it into the bobbin. What is the pros and cons of of this type/style of plate? Thanks
#3 | |
I've seen it mentioned here:
Practical Transformer Winding Quote:
#4 | |
Please see and read this (your own language). Shouldn't be too difficult for Tommy to read too I hope. Last edited by pieter t; 10th January 2012 at 02:41 PM. |
#5 |
hm pieter, what are you referring too? According to your document the MD cut outperforms the EI and M cuts. And I have an article lying around somewhere promising lower inner resistance even than toroids while having a comparable strayfield and size.
#6 | |
I just took a quick look at that Waasner document, haven't read the whole story. In my opinion with whatever EI, M or MD core type you will never reach the same level of power "economics" as is possible for toroids, because of the simple fact that with all stamped laminates the corn orientation is not everywhere "in line" with the magnetic field. Only c-cores and r-cores can approach toroids in that respect. Also strayfields with non-toroids will always be larger because part of the core is exposed to the outside world; only with toroids, where the coil surrounds the whole core, strayfields are small, especially when it is a low T design. Toroids have their own drawbacks however. I'd be interested in the article you have laying around somewhere. |
#7 |
Interesting, according to the Waasner document it is possible to get 60% more power using the MD cut for the same steel weight, compared to M or EI cut, due to better utilization of the grain orientation when using MD cut.
#8 |
power is a function of temperature rise, did that document say what levels of temperature rise is the 60% comparable to?
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#9 |
the obvious, there is just one gap compared to EI's 2......
| M6 lamination: what is it? | jarthel | Tubes / Valves | 5 | 25th January 2012 08:36 AM |
| Lamination Size | ak_47_boy | Tubes / Valves | 30 | 23rd April 2007 02:57 AM |
| Ultra Hi-B 0.03mm lamination start to supply | tube-lover | Group Buys | 5 | 25th February 2007 04:55 PM |
| Page generated in 0.11912 seconds (89.16% PHP - 10.84% MySQL) with 11 queries |
