Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd February 2012, 11:46 PM   #41
hi Andrew, it can be confusing.
To clear things up, my "longer" does not refer to the length per turn of the conductor or total wire-length. It is the length of the coil wich is restricted by core window-length "G", or the width of the window "ba". Air core inductor inductance formulas use coil length "l" in the same way as I do. A longer, more stretched out coil simply means more turns side by side instead of on top of each other.
Old 3rd February 2012, 01:21 AM   #42
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
i remember that in some other threads here, it was suggested that to get that ratio larger and get "longer" layers, use E-E's instead of E-I's.....
i am inclined to try this in some future builds....
Old 3rd February 2012, 09:15 AM   #43
AndrewT is online now AndrewT  Scotland
Gorgon.
would that be the same as a wider layer?
regards Andrew T.
Old 3rd February 2012, 12:34 PM   #44
Andrew,
With all respect: do you have a language problem?
You are asking the same things over and over, and IMO there is clear enough explanation already. YES A LONGER COIL MEANS A WIDER LAYER (is Scottish different from English?)
Old 3rd February 2012, 04:17 PM   #45
The versions of english I see displayed in this Thread are different from mine.
I know of one longer.
Between you lot there seem to be three or four longers describing different things.
It's about time you got a consistent set of definitions.
Start with a diagram. Label it up. Agree that set of definitions.
Everybody sticks with the agreed diagram.
regards Andrew T.
Old 3rd February 2012, 04:38 PM   #46
There is no consistent set of definitions.
Just the fact that values like F, G, ha, ba and others are used illustrate that fact.
I am afraid we can not supply you with a universal diagram with an agreed set of definitions; you have to do something yourself by some sensible deduction.
When everything could be diagrammed with consistent sets of definitions, the world would be quite a bit simpler.
And by the way I don't understand what is so unclear with the "longer" thing.
Old 3rd February 2012, 11:17 PM   #47
Tony's Avatar
AndrewT, merely asking questions can not help you....you have to "do it yourself, DIY" learning by doing and not just asking will get you there.....
Old 4th February 2012, 03:16 AM   #48
Originally Posted by AndrewT View Post
Gorgon.
Andrew, I would say a "longer" coil has usually wider layers.
But i would not say , for example, that a "half layer" stretches out over only half of the coil length.
Old 4th February 2012, 05:02 AM   #49
It is a tradeoff where you exchange the lower frequency advantages of the short coil into the disadvantages of the long coil, and the higher frequency disadvantages of the short coil into advantages of the long coil. As i see it, the possible higher copper to iron ratio of a E-E OPT has advantages. All sort of deviations of the output in respect to input should be possible to get smaller, especially in bigger pp-OPT needing an airgap and symmetric windings.
Since I am into the idea of feeding a OPT from a practically zero impedanz pp-amplifier (with fb taken only on the primary) to reduce distortion, i came up with the idea of using a E-E OPT to complement it. I expect the then resulting high Q can be a problem. Everything is in the design state yet, alltough i have a couple of ideas on how to reduce the capacitance to takle Q.
With higher impedanz feed you would have to accept higher transformer related distortion anyhow, and Q wont be that much of a problem. I can see some advantages in favor of the EE-OPT also in the more usual applications,
as i thinck can anybody that understands what is going on in a OPT used at high audio frequencies.
Old 4th February 2012, 05:05 AM   #50
should read:
As i see it, the possible higher copper to iron ratio of a E-E OPT has also advantages.
M6 lamination: what is it? jarthel Tubes / Valves 5 25th January 2012 08:36 AM
Lamination Size ak_47_boy Tubes / Valves 30 23rd April 2007 02:57 AM
Ultra Hi-B 0.03mm lamination start to supply tube-lover Group Buys 5 25th February 2007 04:55 PM
Page generated in 0.11739 seconds (70.77% PHP - 29.23% MySQL) with 11 queries
