#31 | |
This is not an attack against what you have posted. I simply quote it because it is a good example of 3 "longer" that are being confused by at least me and seemingly a few others. Too many "longer". For the winding, surely the layer is one wire thick or for a 2layer winding, two wires thick. For the width of the layer, it should be the number of wires laid side by side. For the length of the winding we should be measuring the wire length used to wind around the core, times the number of turns in that layer. When referring to magnetic path length, the longer is in a different direction to the longer (of winding) just defined. I see it as the path length around the core that the flux has to travel to get back to the start point for the measurement. As for longer in respect to core, I don't know what this could be. Window area and window shape: Let's define what we mean. Hopefully all confusion will disappear if we agree on what we are actually discussing. Last edited by AndrewT; 1st February 2012 at 12:20 PM. |
#32 |
OK,
Here are the most important abbreviations used in "magnetics" and known to people who are into the matter: - lfe = mean iron path length (yes mean path length around the core); - Afe = net iron cross-sectional area (not the same as height x width!); - Mfe = mass of iron core; - ha = height of winding space; - ba = width of winding space; - lcu = average length of coil winding (average length of one turn); - Acug = geometrical copper cross-section (ha x ba). Source: "Strip wound cut cores" by Vacuumschmelze. |
#33 |
Which in books written in English might more often appear as:
F = window width [cm] G = window length [cm] MPL = magnetic path length [cm] MLT = mean length turn [cm] Ac = effective iron area (D x E) [cm^2] Wa = window area (F x G) [cm^2] Wtfe = iron weight Wtcu = copper weight |
#34 |
Of course there is no standardization in terms.
Ikoflexer: effective iron area is not D x E but about 80 - 90 % of that product (depending on core size). |
#35 | |
http://www.elab.ph/forum/index.php?topic=32688.0 |
#36 |
#37 | |
F and G are geometrical core dimensions; F and G do not take into account the loss of space by the bobbin. For example, for an SG89/51 double c-core Vacuumschmelze specifies ha being 20,1 mm, whereas without bobbin there is 22,2 mm of space. |
#38 |
#39 | |
rated window is still on the short side and will hardly be to long for a audio OPT. The capacity-thing.... The squared effect of the lower voltage/turn of a longer coil givs smaller effective capacitance dispite that more windings are required. The more stretched out coils outside-diam/inside-diam ratio is of advantage. Less Rac copper losses, less interleaving, less capacitance between layers. Less interleaving, higher voltage between layers, higher effective capacitance. Choose your poison ;o) Anyway, high BW does not really leave to much choice, the coil has to be stretched out more than the EI 3:1 window allows. This is one of the reasons M-cores where introduced in the first place. To be more "universallly" usable than what allready existed and surely never was intended for audio use. You clearly get higher BW and lower Rac-losses with the more stretched out coil despite the fact that you need more windings (as is easely confirmed by the high BW toroids can achieve). |
#40 |
Gorgon,
what is your "longer"? A diagram or description maybe. |
| M6 lamination: what is it? | jarthel | Tubes / Valves | 5 | 25th January 2012 08:36 AM |
| Lamination Size | ak_47_boy | Tubes / Valves | 30 | 23rd April 2007 02:57 AM |
| Ultra Hi-B 0.03mm lamination start to supply | tube-lover | Group Buys | 5 | 25th February 2007 04:55 PM |
