variable V out for class a amp
Old 10th January 2012, 05:03 AM   #1
kp93300 is offline kp93300  Malaysia
Default variable V out for class a amp
Hi
i like to build amps to try and hence the need for variable output.
Big Transformers and caps are expensive !
I am looking for suggestions for smps where V out can be adjusted with about 5 amp capability.
I need +/- rails up to 50 V
thanks
kp93300
Old 10th January 2012, 11:59 AM   #2
AndrewT is online now AndrewT  Scotland
I recommend a multi-tapped transformer and build a conventional PSU.
regards Andrew T.
Old 10th January 2012, 12:06 PM   #3
dtproff is offline dtproff  United States
A smps flyback would be your best bet for this topology. You could probably move the Vo about 25% or so without serious loop issues.
Tony
Old 11th January 2012, 04:34 AM   #4
Hi
thanks for the replies.
Seems that it is difficult to buy a smps with a wide range of V out between 24 v to 45 v dc .
kp93300
Old 11th January 2012, 05:18 AM   #5
Originally Posted by kp93300 View Post
Hi
kp93300
You can buy lab supplies that can do it but they are expensive. The loop compensation for these wide range supplies becomes difficult.
Tony
Old 11th January 2012, 06:27 AM   #6
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Hi
thanks
kp93300
you can use a variac so that you can play around with the voltages for your amps....but you will steel need an isolation type power traffo...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 11th January 2012, 12:04 PM   #7
Sorry, I guess I missed something. I thought these were SMPS. My apologies.
Add a 1KVA isolation transformer in from of the variac and you are done.
Tony
Old 12th January 2012, 12:59 AM   #8
Hi Tony,
Thanks for the suggestions which is worth exploring.
regards
kp93300
Old 12th January 2012, 01:02 AM   #9
TonyTecson's Avatar
which Tony? my suggestion is to use the isolation type power transformer after the variac so you can play with input voltages to get the rail voltages you desire....
variable V out for class a ampHide this!Advertise here!
Simple Pre-Amp with Variable High-Pass - This right? domjohnson Analog Line Level 11 11th January 2012 05:58 PM
Adding Variable Impedance to Power Amp mige0 Solid State 41 1st February 2010 06:42 PM
Q: headphone amp with variable distortion vladn Headphone Systems 3 17th February 2008 03:16 PM
powerstat variable transformer 22 amp elghosto Swap Meet 0 7th October 2005 05:46 PM
Horn speaker w/variable throat & mouth bbaker6212 Multi-Way 1 1st August 2003 08:27 AM
Copyright ©1999-2017 diyAudio
