Leco smps some ugly tests... - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th May 2012, 08:19 AM   #31
darkfenriz's Avatar
Originally Posted by DjLeco View Post
Man, it was just a simple test; final one, I think will be full bridge for 1/2 curent on primary, and less Ic on output switching devices.
In that test, I was limmited from small heatsink of rectifier diodes, and resonant capacitor curent cappability...
I have very low loss on switching devices, gratefully almost perfect drive of it, very low rise and fall times.
Look here:
Proper IGBT driving, on mine SMPS (100Khz half bridhe resonant soft switching mode)
Observe ULTRAFAST switching, very low rise and fall timmings.
View image: DSCN5197
Tomorrob (today better said) I will try full bridge tipology, at 62,5 , 100 , and 125 Khz.
Mine IGBT;s are WARP ones (150Khz hard switching, 300 Khz soft switching).
Not interested to use mosfets, due internal body diode, also I don;t want to complicate output topology with schottky and antiparralel diodes too.
All modern SMPS, uses IGBT, or combination of mixed IGBT with mosfet too, also not interested...
Simple one, is most time, the efficient one!
If I lose under 100 Watts per total SMPS at 4000W total load, randament is HUGE, also, musical power is not more than 1/2 from a pure sin wave, or dummy load as I tested.
Next time, I will use, maybe bigger power resistors for dummy load, for longer time testing, If I keept that test, mine 4 ohms resistor will melt itself...
So you switch more than 300V at 10ns rise time (30kV/us) and 15ns fall time (20kV/us) ?
If really so I suggest you slow it down, efficiency is important, but so is EMI.
Old 4th June 2012, 11:17 PM   #32
DjLeco is offline DjLeco  Romania
Send a message via Skype™ to DjLeco
EMI is not so important to me, being resonant mode, and with 2 bobbins at 220Vac main supply (filter) is enough.
Old 3rd November 2012, 06:24 PM   #33
Finally PCB's arived!
I have mounted some components...
View image: DSCN6166
View image: DSCN6167
View image: DSCN6172
View image: Aux Supply OK
Output tensions:
View image: Outputs configuration
Testing signal on IGBT's gates+delay+softstart:
Leco SMPS SoftStart+Delay+Thermal Protection - YouTube
And some final tests, loading till 4300Watts:
Leco SMPS Final Part 1 - YouTube
Leco SMPS Final Part 2 - YouTube
Old 4th November 2012, 07:35 PM   #34
DjLeco, were do you buy your litz wire.
Old 4th November 2012, 08:52 PM   #35
Electrisola, Germany. 600x0.071
Old 6th November 2012, 11:56 PM   #36
More than 5Kw sustained from soket (221Vx25,5A) :
Leco Max Torture Test - YouTube
Main fuse 30A after test:
Sigurante - YouTube
Maximum draw curent from AC plug soket 26A:
Curent maxim SMPS primar.MOV - YouTube
All tests without overcurent protection...
Old 7th November 2012, 03:25 AM   #37
Workhorse's Avatar
DJ Leco,
Greatwork man.
Your smps is ROBUST indeed.
Old 7th November 2012, 06:09 AM   #38
I know!
Thank you for reply!
Old 11th December 2012, 09:24 AM   #39
First SMPS made for one 1000W AB class amplifier, that I've sold last week to a friend, he asked me to make SMPS for that module.
Made at minimum costs, just +/- 100Vdc per power amp, one +12 volts for fan and one +10 volts for one small Mp3 module.
Calibrated for 1800Watts continuous, protection tripping at 2,1Kw
http://postimage.org/image/q0lo5ovtb/
http://postimage.org/image/vq1wq01zj/
http://postimage.org/image/xj4tebn67/
Uncalibrated protection test (without protection)
http://www.youtube.com/watch?v=Cf1VP...ature=youtu.be
Testing with protection enabled and calibrated:
http://www.youtube.com/watch?v=g7I2w...ature=youtu.be
And final test, a big short circuit
http://postimage.org/image/8uz0ncbgv/
Here is testing that amp loaded with 4 ohms, and power raised till around clipping level (almost 960 watts audio), put multimeter directly to + and - , to see voltage dropping at max power out:
Test Final Boxa - YouTube
Old 11th December 2012, 10:03 AM   #40
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
great, just great, nice too see it being done
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Final test: Module Leco vs Crown Powertech Series Amplifier DjLeco Solid State 3 29th October 2013 11:44 PM
Leco amplifier module tested at 2-4 Ohm +/- 99,5Vc DjLeco Chip Amps 0 1st October 2011 07:05 PM
ugly noise DUCKFACE Multi-Way 12 26th November 2010 10:09 AM
Ugly DC-DC SMPS CHACALPOWERS Car Audio 4 25th December 2008 06:11 AM
Copyright 1999-2017 diyAudio
