Leco smps some ugly tests... - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th January 2012, 01:29 PM   #11
DjLeco is offline DjLeco  Romania
Send a message via Skype™ to DjLeco
Main voltage is 220 volts.
Yes , I will use smps's for mine modules, also for selling.
What you see, is a small experiment, just for tests, final work will be very nice.
Being regulated, it will offer constant tension on output in range of 175-250Vac.
Momentanly, I don;t have with what to measure efficiency, I will try a derivation, using clampmeter, ampermeter, voltmeter and shunt.
Soon, test with fullbridge topology, with new windings on secondary and primary, made from litzwire 600 x 0.07 litz, or cooper foil of 37mm x 0,1mm.
Keep close.
Old 13th January 2012, 05:04 PM   #12
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
Leco, ignore those that want it to be something its not
your smps is awsome, I hope to see pcb and some waveforms during video
Again, good job!
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 19th January 2012, 11:25 PM   #13
Again, good job!
Sure I will!
Thanks for appreciation, my friend!
Now, last test before send it for PCB design, and full realisation:
I'm staying on Half Bridge, resonant mode topology.
On first movie, we have around 109-110Vdc on output on 3 dummy load 1 ohm/1000W resistors seried connected (3 ohm total).
For avoiding inadequate measurements caused by tolerance of thermal derive of resistors when heating, I used 100mV/50Amps shunt, so when we have 100mV dropping on shunt, curent is 50 Amps.
On first movie, in this case we have 65,17 mV on shunt, output is 109,8Vdc on dummy load.
If at 100mV on shunt, we have 50Amps, at 65,17mV we will have 50 x 65,17/100= 32,585Amps
In this case power was 109,8Vcc x 32,585A = 3577W
The test at 3500W
Smps 3500W.MOV - YouTube
Now let's make last test.
The test at 3500W
Values are 93,2 mV on shunt, so at 93,2mV we will have 46,6A and dc out dummy load is 103,2V, total power being 103,2Volts x 46,6Amps = 4809 watts.
Leco SMPS Max Load - YouTube
Old 20th January 2012, 06:36 AM   #14
luka's Avatar
this is great, but waveforms or output ripple is unknown
I FEEL SLOVENIA
Old 20th January 2012, 09:23 AM   #15
I made a small movie, loaded with 3500 watts, but in that test, smps is unregulated!
Out ripple.MOV - YouTube
Storage capacitor:
Old 20th January 2012, 09:27 AM   #16
luka's Avatar
why did you put it in unregulated mode?
I think I see primary ripple comming to secondary , totaly normal, I just don't see, what were V/div settings
I FEEL SLOVENIA
Old 20th January 2012, 02:19 PM   #17
I put in unregulated mode, because I just want to see, maximum output power, without any limmitings.
Also protection was disabled.
I have LLC resonant mode SMPS, output with ground coupled, and just 3x470uF/450Vdc capacitors in parralel (equivalent of 2x1500uF seried capacitors), I don't use median coupling (200 Volts seried capacitors), because I don't ever need to use for 110Vac supply (voltage doubler), configuration.
I think 4800 Watts of pure power sustained is OK, from a ETD59 core...
I'm intended to use it for 3500 watts continuous (well cooled) with 4000Watts peak, before shut down (protect mode).
That smps will supply mine class AB modules amplifier 2 or 4 channels (bridgeable) , or one 3000watts TD class amps (wich I will develop, soon).
AB Class almost 1700Watts/2 ohm:
http://www.youtube.com/watch?v=KrenN56u-GY
TD Class, almost 3000Watts /4 ohm, before smps shut down, protection set around 3500 watts:
http://www.youtube.com/watch?v=guoLw...layer_embedded
http://postimage.org/image/2zhjtkx0k/
Old 20th January 2012, 02:24 PM   #18
luka's Avatar
yea, about 5kw is what I hear you can get from 59... and you have showed it also
I FEEL SLOVENIA
Old 21st January 2012, 02:36 PM   #19
I did some tests so try a guide to the approximate calculation of the efficiency of the SMPS, I have the three measurement devices on the same power supply (9V battery brand new) to see how each display, and whether there are differences between them:
multimeters at 9Vdc battery:
multimeters at 300Vdc :
The only measurement where I noticed a slight difference between devices was to measure DC current between the two multimeters (I measured a current through the resistance of 10 ohm to 13.2 VDC powered stabilized) as will be seen in pictures below.
Metrahit show a current 1,316 A and M890G show 1.27 A.
That is why I chose to do the movie 2, where I have replaced each measurement devices between them ...
Now go to see movies, where I extracted and calculated efficiency, obtained by power obtained,dividing by power consumed.
I used the ampermeter seried and voltmeter parraleled with SMPS primary input in order to accurately measure the power consumed by the ratio P = UxI.
I used the ampermeter seried and voltmeter parraleled on SMPS output, loaded with dummy load , to measure the exact power obtained by the ratio P = UxI.
Movie 1 SMPS loaded with 700 + W :
Test 1 Randament SMPS Leco.MOV - YouTube
Test 1 with Metrahit in primary
Primary 296Vdc x 2.55 Amps = 754.8 Watts power consumption
Secondary 120.7Vdc x 5.95 Amps = 718.165 Watts power obtained
Efficiency 95.14%
Continuing movie, above min 3, SMPS is loaded more than 1300Watts
Primary 288Vdc x 4,726Amps = 1361,088 Watts power consumption
Secondary 116,3Vdc x 11,17Amps = 1299,071 Watts power obtained
Efficiency 95.44%
Now I changed measurement units between them, Metrahit in secondary and primary M890G in.
Movie 2, Metrahit in secondary
Test 3 Randament SMPS Leco-001.mkv - YouTube
Primary 288Vdc x 2,55Amps = 759,9 Watts adding 2,6W losses on main rectifier bridge results 762,5W total power consumption
Secondary 121,9Vdc x 6Amps = 731,4 Watts power obtained
Efficiency 95.92%,
Remember, in any of the tests, SMPS was UNVENTILATED!
Old 21st January 2012, 04:27 PM   #20
Sorry for bad pictures above, cannot edit...
View image: Aparate Masura
View image: Aparate masura detaliu
View image: Tensiune secundar 300 Vcc
View image: Detaliu tensiune secundar 300 Vcc
View image: Curent Metrahit
View image: Curent M890 G
Final test: Module Leco vs Crown Powertech Series Amplifier DjLeco Solid State 3 29th October 2013 10:44 PM
Leco amplifier module tested at 2-4 Ohm +/- 99,5Vc DjLeco Chip Amps 0 1st October 2011 06:05 PM
ugly noise DUCKFACE Multi-Way 12 26th November 2010 09:09 AM
Ugly DC-DC SMPS CHACALPOWERS Car Audio 4 25th December 2008 05:11 AM
Copyright 1999-2017 diyAudio
