Hi Gents,
I've picked up a couple of lovely little Rane parametric EQs (FPE13's). I got these from the US, (and live in Australia) so the outboard power supplies are no good to me. And, I also am looking around for a Rane active xover. So, why not build the power supply myself? It's not even really a power supply, as it outputs 18vac (not DC) via an RJ12 line (cat6?). Rane reckon that I'll get a ground loop if I try to use a single transformer and run all the units from a single output - so multiple transformers it is. I've picked up some nice EI trannies from Harbuch, but then I thought "Is there any problem with mounting 4 EI transformers close to each other?" Of course, there's the possible heat problem, but they're only small, and I was planning to have reasonable ventilation in the box. I was more thinking of magnetic interference - would there be any problems there? I'm not in too much of a hurry (still got the old EQ), and Mrs CE insists I build a fence first - as if the gates weren't enough! But I thought I'd plan the PCB, and was wondering if "all in a row" or "squished together in a block" (highly technical terms there!) would be best. I've got a Siemens general purpose filter and a couple of X caps and a fuse - but that is all that is required.
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#2 |
I guess I'll find out the old fashioned way, then.
| Mounting an ei core sideways | studiostevus | Power Supplies | 3 | 15th May 2011 10:06 PM |
| Common-mode EI PS Chokes | rdf | Tubes / Valves | 14 | 17th June 2007 08:36 AM |
| EI transformers. HEAT? | Aunkst | Parts | 2 | 22nd April 2004 05:07 PM |
| EI Vs Toroidal transformers | pcn | Pass Labs | 20 | 14th June 2003 01:36 AM |
| Page generated in 0.06622 seconds (68.80% PHP - 31.20% MySQL) with 10 queries |
