smps for hybride
5 Attachment(s)
Hi All
First happy newyear. I have a plan to make a SMPS for the hybride, contains 2x 140 volt 300mA differential 1 x 450 volt 100 mA and 6.3 volt 10 Amp. Maybe in future also 2 x 60 volt 5 Amp. What I can use best, it can be maybe not easy because of high switchoff induction for driver mosfets, but can snubber that. I want to use simpel, because some people here make supply,s so complicated that is not nessesary with modern pwm ic. some examples in pictures, shema.gif is a weld converter for the ones who need a lot power. So what kind of smps I need, flyback, bridged, half bridge. I have also a idea to use the power trafo of the mosfets stage, it is 60 volt 5 amp, and make a converter who has 24 80 volt input and the tube voltages as output. thanks. |
Since you need high voltage at relatively low current, flyback would be best.
1 Attachment(s)
for also the 60 volt x 2 and 5 ampere extra then I need a bridge one? but can these also deliver high voltage without problems. regards |
1 Attachment(s)
I have made a schematic as example, I can not simulate it with multisim.
Oke, I have use a two mosfet switch for less voltagestress for mosfets I have high output voltage. I know there are more things to do like ntc and such. Let me now what toughts. regards |
very nice site of a guy who torture a switching supply he build.
3 to 60 volts 40 ampere. if you see it then you think, do that work? http://danyk.wz.cz/reg60v_en.html |
| All times are GMT. The time now is 08:22 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
