what whenever i attach a load to my inverter the dc bus voltage drops and in load=400watt input mosfets burns?
inverter is modified sinewave dc bus voltage( no load)=333 volt & input voltage=13 volt dc bus voltage( load=40 watt)=295 volt dc bus voltage( load=145 watt)=277 volt dc bus voltage( load=245 watt)=254 volt dc bus voltage( load=345 watt)=223 volt dc bus voltage( load=400 watt)=205 volt. in power 400 watt after a few seconds input mosfets burns |
#2 |
Without a schematic we can't tell you anything. You didn't even mention the model of your inverter. Anyway, the results you have posted are typical of a cheap chinese inverter with underspec'd dc-dc converter (especially capacitors and mosfets) and no regulation on the DC bus. It isn't worth the hassle to try and make the DC bus regulated, instead try and increase the DC bus capacitor as far as the space allows, and use better mosfets - IRF1404 are a good choice.
"Audio grade" components simply means that they failed at a more critical job. |
#3 |
This is an amplifier power supply, or this is the wrong forum?
| need a schematic for 12v dc - 300 dc inverter | yourownfree | Power Supplies | 9 | 9th October 2011 05:04 PM |
| Krell KSA-150 Bus Voltage | Doral | Solid State | 0 | 2nd June 2007 11:01 PM |
| Voltage drop of various regulators in dc regulated power supply for preamp | duderduderini | Tubes / Valves | 0 | 26th February 2007 11:48 AM |
| voltage drop | ThSpeakerDude88 | Chip Amps | 30 | 19th July 2005 09:00 PM |
| Page generated in 0.06855 seconds (69.90% PHP - 30.10% MySQL) with 10 queries |
