Hi all hope ya all had a good christmas, back to clearing a space and messing around.....
I have a small toroid I want to wire up as a quick use power supply. Its got 2x 115v or single 230v, being in the UK I need the 230v.. The website for the toroid shows wiring as brown and violet to make 1st 115v input and blue and grey as 2nd 115v input... It shows only brown and blue for 230v. Do I tie off the other 2 wires and just connect the 2 for 230v. |
#2 |
Connect the violet and grey together and tape it up and tie it away
#3 |
Taping up the V & Gr pair leaves the two standard colours for Live = brn, Neutral = Blu
But !!!!!!!!! build up a bulb tester and use that to test your newly wired up transformer.
regards Andrew T. |
#4 |
#5 |
Thanks I got a bulb tester that i made when i built last amp.
| This toriod suitable for gainclone | joka22 | Chip Amps | 13 | 1st August 2008 10:12 PM |
| Want to swap toriod for lower voltage toriod | joka22 | Solid State | 0 | 28th July 2008 05:36 PM |
| customer toriod: where can I have mine winded? | jarthel | Parts | 9 | 2nd July 2007 11:34 AM |
| WTS. Toriod 2x55VAC / 500W | Jan Dupont | Swap Meet | 0 | 19th October 2005 08:05 PM |
| toriod transformers | karma | Parts | 1 | 26th February 2003 06:44 AM |
| Page generated in 0.06718 seconds (80.18% PHP - 19.82% MySQL) with 10 queries |
