I'm newbie and right now I have 2 kits of HYPEX uCd 700 kits to begin with, I use 2pcs of TR 700 transformer, one for each amp (dual monoblock) and I'm wondering how to determine the polarity or (or start of winding?) in each transformer so I can connect it identically for each amp.
Is there any way to determine the start of winding of thevtoroidal transformer?
Thank You
Thank You
There is no absolute start of winding in a transformer.
However u can determine the phase relation of the secondary wrt the primary. All u have to do is connect one of the ends of the secondary to the one of the primary connection and measure the voltage from the other end of the primary and the single primary end. The voltage will add or subtract depending on in-phase or out-of phase connection.
The polarity of connection is not of any relevance.
Gajanan Phadte
Gajanan Phadte
Thank You for the reply, the problem is there are a lot of wire with the same color, the primary have 2 black and 2 brown wire for each 115V winding, the secondary have 2 yellow color for 61V etc.....
Here are the link for the transformer that I use:
http://www.hypex.nl/index.php?option=com_weblinks&view=weblink&id=32&catid=42
That is a link to a power supply, not a transformer.
What is your mains voltage? If 115V, join brown to brown and black to black so the primaries are in parallel. If 230V, join the brown of one to the black of the other and then use the remaining two for the supply - primaries in series. In either case a lamp limiter will assist in safe switch-on.
Sorry wrong link, below is the right one
http://www.hypex.nl/index.php?option=com_weblinks&view=weblink&id=28&catid=42
I'm using 230V primary since I lived in Indonesia.
Thank You.
Sent from my GT-P7300 using Tapatalk
Thank You.
If the lamp lights you have a mistake.In either case a lamp limiter will assist in safe switch-on.
Read up on the lamp bulb tester.
what I'm lookin for is to find the configuration of each cable TR700, the example is like the link below, each cable have a color code so determine the polarity is easy
http://www.classicapi.com/catalog/images/gallery/GroupDIY/PSU/51x-toroid-specs.pdf
Thank You
Thank You
This picture from your PDF explains it quite well. The only problem I see is figuring out which is which with the brown and black wires.
You'll need a multimeter for this, set to measure resistance. With none of the wires connected to each other or anything else, there should be a fairly low resistance between the wires marked "A" and "B", and also between "C" and "D". There should be an open circuit (or very high resistance) between either "A" or "B" and "C" or "D".
Easiest is to start with one of the brown wires and check the resistance between that and each of the black wires, to find the one with low resistance. Then do the same for the other brown wire.
When you've got them sorted out, it may be a good idea to tie the pairs together with sticky tape or something, so they don't get mixed up again.
- Power Supplies
- Check toroid winding polarity
