I pulled apart a projection TV and got 2 ferrite with 1/16 ' gaps and cant find data sheet with same dimensions
49mm wide, 54mm high, window 37 x 10 mm, centre leg 17.16 x 18.5 high , outter legs 6mm x 27mm high. I thought if I could find data sheet Id have core material etc . theres no continuity . It had litz wire so its for HF . |
#2 |
You can get nearly any core material in that format, and it is a common size.
If you can measure the saturation curve accurately that will narrow the material selection. |
#3 |
you won't find datasheet if its form Far East.....it is very difficult to find datasheet for Far Eastern ferrite...i try many times.
#4 |
Close enough. http://www.ferroxcube.com/prod/assets/etd54.pdf I'd guess 3C90ish material. A 1/16" gap (surely you measured that in mm as well??) will give you about A_L = 0.21 uH/t^2 and NI_max = 250At or so. Good for maybe a few hundred watts flyback, or a high-ripple forward converter choke, or maybe a resonant type where low magnetizing inductance is required.
Measuring the saturation curve of the material alone will be difficult with the airgap. Few ferrites saturate or overheat at 0.3T or less, so you'd have a hard time screwing it up with conservative estimates regardless of the material. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#5 |
| Air Core inductor: Hole Size ! (waveforms shown) | -_nando-_ | Class D | 67 | 14th January 2008 08:52 PM |
| Selecting audio tranny core size | ashok | Tubes / Valves | 16 | 2nd April 2005 07:49 AM |
| What size core for choke? | Prune | Parts | 27 | 26th September 2004 09:04 AM |
| Amp, Stange temporary buzz, what is that? | gary f | Tubes / Valves | 5 | 25th June 2004 11:06 PM |
| Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer | bmpa | Parts | 2 | 22nd April 2004 04:15 AM |
| Page generated in 0.09213 seconds (73.74% PHP - 26.26% MySQL) with 11 queries |
