I am designing this power supply with the specs: 9V, 3A and current limit kicks in at 2.7Amps. Schematic is attached. I managed to get quite sharp at the output voltage and current limiting but I cannot adjust the current that passes through the regulator. When current limit kicks in, the current through the regulator just stays at 0.85Amps. How can I set is to 0.5Amps at all times? Can you suggest maybe better configurations of the transistors?
| Determining current limit | Neutrality | Solid State | 1 | 31st August 2011 06:12 AM |
| ALW Regulator Current Limit? | fmak | Solid State | 7 | 27th January 2006 08:38 AM |
| how to calculate in rush current limit circuit | demons_wing | Chip Amps | 5 | 26th November 2005 05:57 AM |
| Which NTC to limit inrush current | Mlaen | Solid State | 24 | 10th February 2005 12:52 AM |
| Current limit of EL84 grid? | G | Tubes / Valves | 10 | 22nd February 2003 07:08 PM |
| Page generated in 0.06720 seconds (63.21% PHP - 36.79% MySQL) with 11 queries |
