Magnetising current in a Full-Bridge SMPS?
Old 14th December 2011, 11:54 PM   #11
sawreyrw is offline sawreyrw  United States
Just when I think I understand coupled inductors I run into something like this. I have to admit I had to think about it a little. Of course, it makes sense once you understand it. As an excuse, my initial response might have been somewhat confused because I was thinking about leakage inductance as well as magnetizing inductance. The primary leakage inductance is not coupled to the secondary so that energy must be be dissipated in the primary circuit, and there will be a reverse spike due to it.
Hopefully, this message does not add to the confusion :-)
Old 15th December 2011, 02:03 AM   #12
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Full wave, discontinuous current forward converter works correctly as long as the transformer's secondary-referred inductance is larger than the rectifier load inductance. If this condition is not met, the circuit will behave somewhat like a full wave flyback, with correspondingly poor performance.
The same is not true of full wave conduction (e.g., full bridge phase shift, or a similar circuit could be arranged in push-pull), where the transformer's voltage is under control of the inverter, or of continuous current (large output filter inductor), where the inductor's current accumulates over several cycles and therefore must always be greater than the secondary magnetizing current, which must reset every half cycle.
Since transformer inductance is very easy to have very high, this doesn't concern anyone...
Far more critical is the leakage associated, causing the primary current to persist after the switches turn off, requiring damping of some sort.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Magnetising current in a Full-Bridge SMPS?Hide this!Advertise here!
Help About 8KW Full Bridge SMPS redfox750 Power Supplies 12 9th February 2013 11:50 PM
Full Bridge SMPS is cheaper than Half-Bridge? eem2am Power Supplies 18 28th April 2012 04:32 PM
Half bridge Vs full bridge smps supplies jaiaditya4u Power Supplies 5 27th July 2011 06:12 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 08:23 PM
Copyright ©1999-2017 diyAudio
