Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th December 2011, 05:59 PM   #1
kees52 is offline kees52  Netherlands
Default voltage regulator with two mosfets
Hi All
I just want to now what you think about this one, it simulates good, 10 mA to 1 amp just 100 mv difference in output.
it is a shunt coupled to a source follower, I need it for a hybride who use white follower, on differential supply dc coupled to mosfets.
I have now test it in amp, and he is so quied as a astronaut on the moon, deep black.
for the shunt mosfet you can also use a bjt npn with some changes on his base resistors, but I think mosfets are better, in simulations that is maar in my amp it does good job.
Old 10th December 2011, 06:31 PM   #2
classic design. mosfets are better than the transistors because they keep the power supply low in impedance.
Old 10th December 2011, 08:14 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
Yep. Pretty classic design. I tried that as part of my quest for a high-voltage regulator. I found it inadequate for use in my 300B SET amp for a number of reasons. The pass device would blow on start-up due to SOA violations, the ripple rejection was mediocre, and the output voltage varied quite a bit with temperature. I eventually ended up designing a floating high-voltage regulator.
With your relatively low voltages (125 V input), you do have the benefit of being able to choose components that offer more gain. Having access to low-voltage electrolytics so you can get a decent amount of cap in a small package works in your favor as well. Specifically, the C4-R4 time constant in your circuit (main ripple rejection filter) works well with a sizable cap.
Obviously, the circuit works in your application. Good work... Just sayin' that it's hard to scale it up to higher voltages.
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 10th December 2011, 08:31 PM   #4
~Tom
For very high voltages there are always limitations, but I have need only 2 x 110 volt for white follower in hybride, and it simulates very nice, I have to say that in these days there are a lot very high bjt and mosfets, shunt it with a zener can protect it when startup, but has some danger in case the zener fails.
Yes tube supply is always a challence, but with the modern fets these days we can make good regulators.
Old 11th December 2011, 04:27 AM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Than bipolar junction transistors I assume you mean?
This is incorrect because BJTs have higher transconductance than MOSFETs do, at comparable operating conditions.
This doesn't matter much, because the circuit shows a big fat 22uF crushing the loop response. The output impedance of this regulator will be approximately 1/Gm of Q1, which will be in the 10s of ohms range most likely.
If R4 and C4 were removed and a small compensation capacitor (or R+C) placed across R2, and the values adjusted until critically damped transient response is obtained, you will have the lowest possible output impedance and highest PSRR. I would guess Zo will be in the miliohms, especially with BJTs, while PSRR will be >40dB.
Further improvement can be made by reducing the bias current supplied from R3; 100k or even 1M will suffice here, at some expense to high frequency response (which is easily compensated for with a customary filter capacitor on the output). This also relaxes the operating point for BJTs, which are often 2nd breakdown limited at these voltages and higher.
As a final step, the error amplifier can be changed from a single transistor to a differential pair, at the expense of one small transistor; this will essentially transform the tempco from an obvious Vbe error down to the error of D1, which could also be replaced by a lower voltage zener (with predictable tempco), or a bandgap reference such as TL431.
Then you'll have essentially the regulator circuit I built here, with a bit higher current capacity:
For that matter, this circuit will do an excellent job under the same conditions, replacing the pass transistor with a MOSFET and adjusting the current shunt resistor accordingly.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 11th December 2011, 04:44 AM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Actually, it is not so classic: reference voltage for the follower is taken from capacitor, and feedback loop is slow.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 11th December 2011, 07:43 AM   #7
There is a small capacitor (C6 = 220nF) across R2. Read somewhere else that it improves the PSRR by about 10dB?
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 11th December 2011, 09:00 AM   #8
Should there be a current limitation too ?
It is only one transistor and resistor more.
Like this: Click the image to open in full size.
Old 11th December 2011, 12:13 PM   #9
I have seen on this forum a lot of regulators, also this is from electuur kilowatter mosfet amp. I did now then that the regulator 7808 did blow because of the capacitors cause short until she are charged, I did use zeners to protect and this did work nicely.
this regulator TL783 is a nice one for a floating supply, see the link.
http://www.ti.com/lit/ds/slvs036m/slvs036m.pdf
Old 11th December 2011, 08:28 PM   #10
Sch3mat1c's Avatar
Oh, there it is. It will improve AC midband response by approximately the voltage divider ratio (270k into 20k, a bit over 20dB), if the loop were able to function (which it can't, since R4-C4 is several decades slower).
A resistor in series with C4 may be necessary to limit the amount of AC loop gain; too much and it can be unstable. This is more likely with more gain stages (less phase margin).
Tim
Small signal, low thresh-hold voltage MOSFETs jackinnj Solid State 0 19th April 2009 07:24 PM
Voltage regulator help audiobahnkid592 Class D 5 12th March 2007 10:01 AM
Voltage Regulator ! jleaman Power Supplies 11 13th May 2005 12:00 AM
Voltage regulator annex666 Solid State 1 27th August 2003 02:50 PM
What voltage regulator to use? Thomas Everything Else 2 28th September 2001 02:53 PM
Page generated in 0.12788 seconds (81.46% PHP - 18.54% MySQL) with 11 queries
