Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th December 2011, 01:52 AM   #1
Default Proffesional Digital Power Supply 4 Lab projects
Hi all,
I looking 4 building a very stable & professional digital power supply that have the following basic requirements:
-Dual output voltage (i don't have CT transformer).
-Have 3 to 4 varying ranges (One dual , other are positive only)
-Output voltage vary from -24 : 0 : 24 (-ve voltage for dual channel only)
-At lest provide 6A output current at all loads.
-Have a digital 2x16 LCD to provide the output voltage & Current measurments that are calculated via AVR Microcontroller (Note: i may require selector switch here to select between 3-4 output channels).
-all the output voltage & current are adjustable.
-(optional) instead of using pot resistor to adjust the voltage & current , can i make it digitally adjusted through the microcontroller using tack switch or something similar
-Also i hope to provide a all output channels with overcurrent / over voltage / short circuit protection
In my country i only have transformer with 240:24(3A) , no CT Transformer (So how many transformers that i need , and how to connect them properly )
I know that power supply will be be large and have a very complex circuit & will cost me lot & need large box ..
I need some schematics , ideas that can help me building this dream .. Also can i build all of that in Plastic box (I don't have any ready steel box with proper size to hold all of that ).
Waiting all of u ..
Old 10th December 2011, 07:05 PM   #2
Any Ideas or Help Please ..
Old 12th December 2011, 09:46 PM   #3
magnu is offline magnu  Sweden
Agilent has some old service manuals on their web site, including schematics, with adjustment instructions.
http://cp.literature.agilent.com/lit.../5950-5976.pdf
There are plenty more manuals, from where this came from.
Lab Power Supply Design / Build MJL21193 Power Supplies 175 5th March 2011 02:02 PM
Lab Power Supply Nikon1975 Tubes / Valves 2 11th December 2009 10:52 AM
Regulated Lab DC power supply Sir Trefor Tubes / Valves 6 28th July 2007 06:13 PM
diy dual lab power supply morpheus82 Power Supplies 25 10th July 2006 12:41 AM
Lab Power Supply Current Limiting Q Wynand Equipment & Tools 4 27th September 2005 10:44 PM
Page generated in 0.08183 seconds (70.26% PHP - 29.74% MySQL) with 10 queries
