Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th December 2011, 07:47 PM   #11
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by Soundminded View Post
Yes, a voltage divider consists of to or more resistors in series, the voltage dividing in proportion to each resistor compared to the total resistance. When you connect a load, you are connecting it across one of the resistors. If the load resistance is not an order of magnitude larger than the resistor it is being connected across, it will reduce the parallel combination of itself and that resistor and will therefore reduce the proportion of voltage across them. This is basic DC electricity.
The load is connected from output to gnd, in effect in parallel to the series string, and not across one of them.
BTW, aside from the minimum load for the regulator as noted, you also have a small Iadj current coming out of the adj terminal.
To make sure that that current doesn't impact the design value for the resistive divider, make sure that the current through the divider string is at least an order of magnitude larger than the iadj current. That will also take care of the minimum load, killing two flies with, ehhh, two resistors.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 8th December 2011, 10:29 PM   #12
Across means in parallel. The string should also end at ground. It should be in parallel with one or more resistors but not all of them. Any other arrangement and it's not a voltage divider.
This novice needs help with Voltage divider jeffreybehr Solid State 11 25th October 2011 09:28 PM
OT: Noob needs help with voltage divider basics interestingfellow Parts 18 18th August 2011 02:58 PM
voltage divider in WE91 driver bobluis Tubes / Valves 2 27th August 2010 01:37 AM
Precision Voltage Divider - diy redrabbit Equipment & Tools 3 24th July 2008 04:16 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 05:19 PM
Page generated in 0.07765 seconds (68.57% PHP - 31.43% MySQL) with 10 queries
