Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th December 2011, 08:45 AM   #1
frasco is offline frasco  Finland
Default Quick noob question about SMPS
Can I use the following SMPS to power a hifi amp using two LM3886 chips?
120W Single Output Regulated Switching Power Supply 24V 5A Universal AC input
To clarify, can I split the output to the two chips feeding them both 24V 2.5A or do I need two SMPS's instead?
I'm planning to drive a pair of small 8 ohm 2-way speakers so the effect should be enough I think?
Old 4th December 2011, 08:49 AM   #2
KatieandDad's Avatar
That SMPS has a 24V input NOT 240V.
It is designed for use in a truck.
Old 4th December 2011, 08:53 AM   #3
Whoops, something like this then?
Regulated Power Switching Supply AC to DC 24V 5A 120W | eBay
Old 4th December 2011, 08:59 AM   #4
Hmm are you sure? From the link:
Features:
Universal AC input / Full range
Old 4th December 2011, 09:14 AM   #5
Send a message via Yahoo to Th3 uN1Qu3
Does it say anywhere about +/-24v? No it does not, it only has one single 24 volt output referenced to ground. There is no negative output and your chips need that so it's not going to work. It's also too low power for your needs, i'd suggest at least 300W.
"Audio grade" components simply means that they failed at a more critical job.
Old 4th December 2011, 09:52 AM   #6
I'm more confused now than before, thanks!
Gonna have to read up more on power supplies.
Old 4th December 2011, 05:44 PM   #7
jitter is offline jitter  Netherlands
jitter's Avatar
The "24 V AC input" is an error in the text.
Skip to the end of the eBay link and you'll find the specs. The input ranges from 176-264 VAC and it only has a single 24 VDC out. The second eBay link shows a similar SMPS.
Both are unsuitable.
Old 4th December 2011, 06:29 PM   #8
Mooly's Avatar
Is there any reason you want an SMPS rather than conventional linear type ?
A simulation free zone. Design it, build it, test it.
Old 4th December 2011, 07:32 PM   #9
The main reason is probably that I was misinformed/ignorant and thought those power supplies on Ebay would be cheaper compared to building a "normal" PSU based on a transformer.
Old 5th December 2011, 03:18 AM   #10
carcass is offline carcass  Portugal
well, according to nuuk, you are indeed not misinformed
SMPS for the Gainclone chip amp
cheers
regarding your ebay smps though, you have to be careful, since even the dual output ones rarely get the same power rating at both rails.... so try to find 2 of them (large enough that is)
Noob here, quick question j0ckinjz Class D 19 14th May 2010 07:07 PM
Quick SMPS question... Mistertaz Class D 0 27th May 2008 10:37 PM
SMPS :noob: question Low Rider Power Supplies 1 27th March 2008 03:17 PM
Quick Noob Question: better DVD-A DACs? x-pogo Digital Source 1 15th December 2007 09:23 PM
noob question, quick answer bigphil Parts 16 16th June 2006 02:54 AM
Page generated in 0.09639 seconds (88.71% PHP - 11.29% MySQL) with 10 queries
