Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th December 2011, 06:45 AM   #11
Mooly's Avatar
Using two or four SMPS of what are really unsuitable spec cobbled together isn't my idea of good design practice.
A simulation free zone. Design it, build it, test it.
Old 5th December 2011, 05:55 PM   #12
carcass is offline carcass  Portugal
well, using national papers... (assuming the OP need for a smallish 30W 8ohm amp)
sqr(2*8*30)
vopeak=21.9V
sqr((2*30)/8)
~2.74A
Iopeak=2.75A
supply required=+- 25.9V@2.75A
easily managed using the smps calibration pots (the cheap ones found on ebay all seem to have it, this one for instance: 24V 10A DC Universal Regulated Switching Power Supply | eBay
And I found another well wroten article about it...here
ps it also as an alternative linear ps for "sensitive" minds... no pun intended
Old 6th December 2011, 06:50 AM   #13
frasco is offline frasco  Finland
Interesting article, I've read it before, that's why I "knew" it could be done. He's using two 60W supplies though. Cool idea to integrate a cheap USB dongle too!
Old 8th December 2011, 02:21 AM   #14
nice article yes, soft start for the smps, inductor filtering, thermal protection...the works, however doing the math for a 40W amp as he suggests one would need approx. 93W (29V@3.2A) to support the peaks, and as it's always best to have some headroom as we don't really know about the smps efficiency, double that to ~200W or just use two of the ones I've suggested before....
Old 9th December 2011, 12:15 AM   #15
What about using LM1875 instead of LM3886 and power them with two 19V 3.42A laptop wall warts in a dual mono configuration? That would certainly fit my budget and 65W per channel should be fine for the LM1875. How's that for an idea?
Old 9th December 2011, 03:49 AM   #16
sure if you want to try getting roughly 13-15W from it... don't forget some smoothing caps after those supplies try 2x2200uF 50V per rail for a start....normally those smps are indeed noisy, so that small inductor we've talked about doesn't hurt either.
go see the datasheet
Old 9th December 2011, 04:07 AM   #17
CBS240 is offline CBS240  United States
CBS240's Avatar
You can order a toroidal transformer kit for less than using multiple SMPS's strung together for a more reliable power supply. Most kits come with pre-wound and insulated primary/w thermal fuse. All you need do is wind the secondaries you need.
All the trouble I've ever been in started out as fun......
Noob here, quick question j0ckinjz Class D 19 14th May 2010 07:07 PM
Quick SMPS question... Mistertaz Class D 0 27th May 2008 10:37 PM
SMPS :noob: question Low Rider Power Supplies 1 27th March 2008 03:17 PM
Quick Noob Question: better DVD-A DACs? x-pogo Digital Source 1 15th December 2007 09:23 PM
noob question, quick answer bigphil Parts 16 16th June 2006 02:54 AM
Page generated in 0.09518 seconds (75.95% PHP - 24.05% MySQL) with 10 queries
