Hi All,
Im looking to build a DC>DC power supply for my DEQX which is currently in my car running off a pure sine wave inverter. I would like to do it myself with a kit or design, but unable to find one on the net with the specs I need. I need it to be stable and perform flawlessly. 11v-15v input +/- 15v rails at .6 amps Can anyone help me out with directions to a design or kit or design one for me that I can build. I have very good soldering skills and have made plenty of KITs in the past. Thanks for any help. Antony |
#2 |
perhaps the easiest way is to build the DC-DC converter off standard unit such as link below by Traco.
http://malaysia.rs-online.com/web/p/...rters/4414043/ http://docs-asia.electrocomponents.c...6b801a62bd.pdf |
#3 |
Thanks Calvin,
Would I just stick this on a board and provide 12v from the battery use the earth as the common earth for the outputs? Ant |
#4 |
Simplest method would be something like this:
Digi-Key - 102-2367-ND (Manufacturer - VYB20W-Q24-D15-T) |
#5 |
There should be some protection from noise and transients on the 12V supply. An inductor, fuse, capacitors, transient absorber. And if you want a really clean 15V, use a higher voltage DC-DC converter followed by linear regulators.
If you can scrounge a smallish power amp with a good power supply but blown amp(s), that would be overkill as far as power goes. You might be able to use the supply as-is and just add linear regulators to drop the voltage. Or rewind the transformer secondary and adjust the feedback sensing for lower voltage. |
| 12V -> 170V DC/DC smps, what's wrong? | markusA | Power Supplies | 5 | 28th March 2011 09:02 PM |
| use of dc-dc converters in high power amps supply | guyst | Power Supplies | 0 | 13th April 2010 03:12 PM |
| DC-DC buck regulator layout -> what's your opinion? | Danko | Power Supplies | 14 | 31st December 2005 03:31 PM |
| DC-DC Power converter for Class T amp power supply? | rtalk | Class D | 2 | 7th December 2004 04:02 AM |
| Diy Dc-dc Pc Power Supply , Anyone? | CAR_LCD | Car Audio | 8 | 23rd March 2004 07:28 PM |
