#2 |
Don't wear anything metal while testing it.
#3 |
If you get an old microwave, get the transformer out of it, cut off the secondary, wind a new one (will need around 50 - 60 turns) you will get around 1.5 kW - 2.3 kW if you take the ballasts out.
#4 |
Use a safety goggle when you switch it on for the first time.
Is it a SMPS or lineair? And is there any way that you can test it for functionality with reduced power. |
#5 |
it is linear PS , I will use it as a supply for an inverter.
#6 |
yes it is a Linear PS.
#7 |
Input series resistors are your friends during initial low load power up.
#8 |
OK. is there any way to regulate the output of a rectifier bridge ?
#9 |
have you built linear power supplies before?
#10 |
I doubt the primary in a microwave transformer is wound for continuous high power operation.. I'm not in general a fan of newbies recycling potentially dangerous parts into a project.
www.kta-hifi.net |
| High power SMPS 2kw 400v DC | Dizipia | Power Supplies | 6 | 8th March 2011 09:09 PM |
| Need Help In making power supply! :( | nobody0725 | Power Supplies | 15 | 14th September 2009 11:47 PM |
| Making your own winding for auxiliary supply | rtarbell | Parts | 2 | 4th March 2008 07:36 AM |
| active crossover power supply pcb check before making | mazurek | Solid State | 20 | 2nd May 2006 12:17 AM |
| active crossover power supply pcb check before making (was in wrong forum) | mazurek | Power Supplies | 0 | 29th April 2006 10:25 PM |
| Page generated in 0.09850 seconds (79.03% PHP - 20.97% MySQL) with 10 queries |
