#31 |
Suggested procedure :-
Remove the blown cap. Measure across the large cap - it will probably measure short but the fault is most probably elsewhere. Remove the TOP 261 - short probably goes away. Check all diodes on the mains side - this can probably be done in circuit - 0.6 volt forward drop, something more reverse, if in doubt lift one end. Check all resistors in the area. Check the O/P connection for a dead short Replace any faulty components, this will almost certainly include the TOP261. |
#32 |
Thanks Barry.
#33 |
I think Barry has put you on the right track. Just wondering if that cap failed due to a transient or defect or failed as the result of something else failing first. Be sure to replace that cap with the exact same type which I suspect is probably an X2 - hopefully it is still legibly marked on the case.
www.kta-hifi.net |
| Biasing/thermal compensation of Thermal Trak transistors | Bob Cordell | Solid State | 156 | 11th December 2010 08:38 PM |
| Worth doing cheap "thermal protection fuses" in hot amps? | cfcubed | Pass Labs | 4 | 15th June 2008 02:27 AM |
| help with Thermal Impdeance vs. Thermal Conductivity | Eric | Pass Labs | 4 | 22nd July 2005 07:23 PM |
| Thermal compensation | lumanauw | Pass Labs | 1 | 23rd April 2005 07:32 PM |
| Page generated in 0.06433 seconds (72.87% PHP - 27.13% MySQL) with 10 queries |
